New European standard 5V1A plug S-100D
Official specifications:
Input voltage range AC100-240V. Wide voltage input, in line with global use standards.
Input voltage frequency: 50-60Hz.
Output voltage range: 5V
Output current range: 1A
Output voltage adjustment rate: 5%
Output ripple & noise 100mVp-p. DC ripple is small, high work efficiency, low temperature, long service life,
Working efficiency 80-85%. Low power consumption design, no-load power consumption is small
Output short circuit protection. Built-in overcurrent. Overvoltage protection
Working temperature 0 °C ~ +50 °C.
Storage temperature –20 ° C ~ +85 ° C.
The above specifications do not really have anything with this charger to do as my tests show
I got it from Ebay dealer: fgjt935
Measurements
Power consumption when idle is 0.14 watt
USB output is coded as USB charger (DCP)
Weight: 15.7g
Size: 65.3 x 34.5 x 14.5mm
The 1A rating is rather optimistic, a 0.7A rating looks more realistic.
At 120VAC it can only deliver 0.5A
I did the 1 hour test at 0.7A, the output voltage drops a bit when the charger gets warm.
M1: 48.2°C, HS1: 78.9°C
HS1 is the transformer.
M1: 43.7°C, HS1: 54.7°C
M1: 75.9°C, HS1: 78.5°C
Here HS1 is the rectifier diode.
HS1: 78.0°C
HS1: 78.9°C
This charger has a lot of spikes on the output when unloaded: 64mV rms and 1063mVpp
At 0.5A load the noise increases to 141mV rms and 921mVpp.
Tear down
It was fairly easy to break the mains pins off and pull it apart (This by itself is bad safety).
The circuit has a bridge rectifier and uses two transistors instead of a IC, there is a opto coupler from the low volt side. On the low volt site is a small rectifier diode and a zener diode in series with the opto coupler.
There is no safety capacitor, but instead a 1kV ceramic capacitor, this is also a safety risk.
The safety capacitor is not even soldered (This do not eliminate the safety risk).
There is about 1mm between mains and low volt side, there is supposed to be around 6mm!
It failed both the 2830 volt and 4242 volt test, this makes it dangerous to use anywhere in the world.
Conclusion
The power supply has lot of noise, cannot deliver rated current and is dangerous.
Stay away.
Notes
The charger was supplied by a reader for review.
