Nitecore IMR18490 1100mAh (Black-Yellow)
Official specifications:
Capacity: 1100mAh
Minimum capacity: 1070mAh
Nominal voltage: 3,6V - 3,7V
Charge voltage: 4,2V ± 0,05
Discharge cut-off: 2,75V
Pluspol: ButonTop
Max. continuous discharge current: 11A (10C)
Chemistry: IMR (LiMg)
Protection circuit: None
Charge algorithm: CC-CV
Diameter: 18,15mm ± 0,05
Height: 49,05mm ± 0,12
Weight: 32g±1
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-info.png)
A fairly high current 18490 (Basically same as 18500) cell from Nitecore.
/DSC_8271.jpg)
/DSC_8273.jpg)
/DSC_8272.jpg)
/DSC_8283.jpg)
/DSC_8284.jpg)
/DSC_8285.jpg)
/DSC_8286.jpg)
/DSC_8287.jpg)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Capacity.png)
The two cells have different capacity and do not handle high current the same way. It looks like they can handle 10A
I got a fairly high internal resistance, because I measure it at high load.
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Temp-10.0.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Temp-15.0.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-CapacityTimeHours.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-CapacityTime.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Energy.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-PowerLoadTime.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-TripCurrent.png)
/Nitecore%20IMR18490%201100mAh%20(Black-Yellow)-Charge.png)
Conclusion
The performance is fairly average for 18490/18500 high current cells, but the bad matching means they cannot be used in series.
Notes and links
Compare to 18650 and other batteries
