Orico 3-port Mobile Phone Charger WHC-3U
Official specifications:
Brand Name: Orico
Output Interface: USB
Max. Output Power: 15w
Quality Certification: RoHS
Quality Certification: ce
Model Number: WHC-3U
Applied Fast Charge Protocols: No Support
Power Source: USB
Input: 100-240V/0.3A
Type: Travel
Item: ORICO 3-port Mobile Phone Charger
Material: PC+ABS Fireproof
Input: AC 110-240V 50/60HZ 0.4A
USB Output: 5V2.4A*3, MAX15W
Protection: Over-heated/Over-current/Over-charging protection
Plug: EU Plug
Color: Black/White
I bought it from Aliexpress store Orico Official Store
It arrived in a cardboard box with specifications.
The box included the charger and a instruction sheet.
Measurements
Power consumption when idle is 0.06 watt
USB outputs are coded as auto with Apple 2.4A, Samsung, DCP
Weight: 68g
Size: 88.4 x 58.3 x 27.3mm
The first output can deliver 3.7A
The same with another output.
And all outputs together is also 3.7A
At 120VAC it drops to 3.5A, this better than the rated 15 Watt
The charger can deliver 3A for one hour.
M1: 65.5°C, M2: 42.3°C, HS1: 65.8°C
HS1: 56.7°C
M1: 63.8°C, HS1: 69.0°C
HS1: 68.2°C
M1: 47.8°C, HS1: 64.7°C
At 0.5A the noise is 7mV rms and 339mVpp.
At 1A the noise is 10mV rms and 330mVpp.
At 2.5A the noise is 22mV rms and 362mVpp, generally the noise is low.
Tear down
As usually with this design I could mount the base in my vice and break the top off to open it.
On this side is the input fuse (F1: 2A), two mains smoothing capacitors (EC1 & EC2) with a inductor between (L1). The safety capacitor (CY1) is mounted close to the USB connectors. There is a large switching transistor (Q1). On the low volt side is also two smoothing capacitors (EC4 & EC5) with a inductor between. Both inductors are glued to a nearby capacitor to make it more stable if the charger is dropped.
The mains switcher (U1) is a rather small chip. On the low volt side is the synchronous rectifier (U2: Marked OSC7710) and two auto coding chips (U3 & U4)
The distance between mains and low volt side is well above 6mm.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger is nicely designed with low noise, good safety and auto coding. Only problem is that is has 3 USB outputs, but not much more power than one output can use.
Notes
How does a usb charger work?
