Came out in 2013 iirc, meant as successor to the NCR18650B, but was pulled when Panasonic/Sanyo brought up BD, BE, BF, BL and GA.
It is interesting to see how little gain there is to the NCR18650B. And the curve perfectly matches the GA, just lower at higher current. Seems to be the same chemistry. Perhaps still with a PTC.
Nah, the internal resistance is a bad indicator as it is very difficult to get proper, comparable results.
But HKJ’s comparator lets us compare the discharge curves, where you can see the gain of the G over the B:
NCR18650G (red) vs. NCR18650B.
Clearly an improvement over the B when it comes to voltage at all three discharge currents. But the difference in capacity seems to be only below 2.8V.
And here the NCR18650G (again red) vs. NCR18650GA.
Here the GA has the edge over the G at higher current, but not at 0.2A, where it’s virtually identical.
It’s interesting to see how the G and the GA have the same kind of curve at all three current levels, just with increasingly lower voltage at higher currents. Looks like very similar chemistry, but the the G seems to have more resistance.
Never use these “Panasonic NCR18650G 3600mAh” and “Panasonic NCR18650B 3400mAh” for laptops, because they will always be useless due to low voltage. With them, your laptop will be much faster to disconnect, despite the superiority in capacity. Yes, they will still have a lot of remaining capacity, but this will not make sense since the laptop still goes into standby mode to start charging.
I still also don’t understand where they have 3600mAh, if even with a discharge current of 0.2A you can get only 3300mAh?
