Proelio Universal USB Charger XKY-024
Official specifications:
Brand Name: Proelio
Model Number: Universal USB Charger
Support Quick Charge Technology: No
USB Ports: 2
Quality Certification: CE,RoHS,PCT,CCC
Output Interface: USB
Input: 100-240V/0.6A
Output: 5V/2.1A
Power Source: A.C. Source,USB
Colors: White
I got it from aliexpress dealer POP Finger Holder Store
It was packed in a plastic bag inside the usual envelope.
There is a led behind the front of the charger.
Measurements
Power consumption when idle is 0.12 watt
Both USB output is as usb charger (DCP)
The two outputs are in parallel.
Weight: 37g
Size: 86 x 36.5 x 36.5mm
Output can deliver about 2.3A before it drops.
It is the same for the other output.
And also when using both outputs.
But not at 120VAC, there it can only deliver 1.7A
Running 1 hour at 1.7A worked fine.
M1: 59.9°C, M2: 52.9°C, HS1: 60.3°C
HS1 is the transformer.
M1: 63.3°C, HS1: 65.7°C
HS1: 51.1°C
HS1: 97.9°C
HS1: 75.3°C
HS1 is the rectifier diode.
At 0.5A the noise is 146mV rms and 1094mVpp.
At 1A the noise is 252mV rms and 1297mVpp.
Tear down
Placing the charger in my vice and whacking one with my mallet did open it.
At the mains input is a glass fuse and a brudge rectifier, the switcher (RM6204) is on this side, together with the opto-coupler. There is a large rectifier diode near the usb connector. The “blue safety capacitor” is not a safety capacitor, but just a 1000V capacitor
On this side is the usual reference (Q1: 431).
The creepage distance is about 1.5mm, this is way to short.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The high voltage test did not show safety problems, but there are due to too short distance and a unsafe capacitor. Performance varies with voltage and there is a lot of noise in the output.
Stay away from this charger.
Notes
How does a usb charger work?
