Test/Review of Samsung ETA U90EWE (fake)
This is a 5V 2A rated usb power supply/charger.
Official specifications:
  • Input: 100-240V ~50/60Hz Max0.35A
  • Output: 5.0V-2.0A
The charger was bought on ebay from fagofago
I got it in two plastic bags.
The charger and a usb cable.
The adapter looks like the real Samsung adapter, but it is not.
Measurements
  • Idle power consumption: 0.013W (Very good)
  • Usb coding is Samsung tablet.
Output voltage is increased with load, this will compensate for losses in cables. The efficiency is around 80% and overload protection kick in at 2.2A.
One hour with 2A load is not problem.
The temperature photos below are taken between 30 minutes and 60 minutes into the 1 hour test.
M1: 55,3°C, HS1: 74,2°C
It looks like the transformer is getting warm.
HS1: 76,7°C
M1: 60,6°C, M2: 55,0°C, HS1: 62,1°C
M1: 50,6°C, HS1: 64,2°C
There is not much noise, 26mV rms and 340mVpp. at 2A.
At 0.5A the noise is slightly lower with 14mV rms and 230mVpp.
Tear down
With a bit of work I could pop the lid on the charger.
I could pull the circuit board out.
On the input side there is a fuse, ptc, inductor and a bridge rectifier.
The blue part is a safety capacitor.
The two green capacitors are marked 105°C, very good and also needed with the temperature it reaches.
But everything is not perfect, for 230VAC equipment there must be about 4 mm between mains and low volt side, this charger does not have enough space. If there had been some plastic wall in the slot it might have passed.
The charger passed a isolation test with 2500 volt, but failed a 5000 volt test, this makes the charger acceptable for 110VAC usage, but doubtful for 230VAC usage. With a 230VAC plug in the charger it is not acceptable.
Conclusion
When running at 2A the power supply gets hot, but it might be designed for it. Generally the performance is very good for this charger and if it had passed the 5000 volt test and there had been some plastic in the slot I would have taken it for a genuine Samsung.
But with the short isolation distance and the failed test it cannot be genuine.
Notes
The power supply was supplied by Andrej that got it from ebay dealer fagofago
AFAIK it’s 4mm creepage (on PCB), but 2mm clearance (air gap).
Which regulation requires 5kV isolation test voltage for 230V equipment?
Electrically, this USB supply looks perfect. I’m not yet convinced it is fake.
Thanks HKJ!
Also I’m subbed to learn a little more if HKJ/anyone responds to light-wolff.
Subscribed.
Here are the usb chargers you promised. I’ll wait for a few more
Reinforced isolation for mains voltages between 150 and 300 volt requires 4 mm clearance for pollution degree 1 to 3.
ISO60950-1 reinforced isolation is 3000VAC, but is usual tested with the DC equivalent that is 4242 volt, the nearest setting on the tester is 5000 volt.
I got some pictures showing what is supposed to be the real Samsung supply, it looks the same but has a piece of plastic in the gab.
