Test/Review of Samsung INR18650-20Q 2000mAh (green)
Official specifications:
  • Battery Capacity (Mfg Rated): 2000 mAh
  • Battery Chemistry: LI-Ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: 18650
  • Battery Maximum Voltage: 4.2 V
  • Battery Minimum Voltage: 2.5 V
  • Battery Rated Voltage: 3.6 V
  • Current Output: 15 A
  • Brand: Samsung
  • Diameter: 18.1 mm
  • Height: 64.8 mm
  • Product Weight: 43 g
Thse are high power batteries for use in tools.
The cells can deliver 20A with full capacity and the maximum difference in capacity is about 0.6%.
The voltage at the lower currents is not very impressive, but in the 10A to 20A range it can match IMR cells, but with greater capacity.
Conclusion
This is a very good battery, but there is no reason to use it, except if you need a lot of current.
The R version of the battery is slightly better.
Notes and links
Comparison to other LiIon batteries
Very nice tests, thanks for the review!
Thanks for the review!
Really nice to be able to compare it with other batteries on your webpage! :)
Nice!
Take that voltage sag!
wow!
thanks so much for testing this battery, i was hoping for far less voltage sag so this is very informative to me
