Samsung INR18650-25R 2500mAh (Cyan) Ebay
Official specifications:
Style: Flat Top
Chemistry: INR
Nominal capacity: 2500 mAh (2200 mAh)
Max Continuous Rated Discharge: 20A (at 25 degrees Celsius)
Max Pulse Current (Less than one Second Pulse): 50A
Dimensions: 65.0 ± 0.2 mm (L) x 18.3 ± 0.2 mm (D)
Weight: 45g (Max)
Discharge Cut-off Voltage: 2.5V
Nominal voltage: 3.7V
Full Charge Voltage: 4.2V ± 0.05V
Cycle info: Capacity drops to 60% after 250 full charge/discharge Cycles
Standard Charge: CC/CV at 1A / 4.20V ± 0.05V, 100mA Cut-off
(Max) Rapid Charge: CC/CV at 4A / 4.20V ± 0.05V, 100mA Cut-off
Operational Charging Temperature Range: 0 to 50 degrees Celsius (Best below 45 degrees Celsius)
Operational Discharging Temperature Range: –20 to 75 degrees Celsius (best below 60 degrees Celsius)
You can store them for 1.5 years at –30 to 25 degrees Celsius, 3 months at 30 to 45 degrees Celsius and 1 month at 30 to 60 degrees Celsius (in other words, store them in a cool place and they’ll last longer)
What do you get when buying a Samsung INR18650-25R on Ebay?
%20Ebay/DSC_9618.jpg)
%20Ebay/DSC_9620.jpg)
%20Ebay/DSC_9622.jpg)
%20Ebay/DSC_9623.jpg)
%20Ebay/DSC_9624.jpg)
%20Ebay/DSC_9625.jpg)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-Capacity.png)
The two cells match fin, but capacity is lower than rated value.
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-Temp-10.0.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-Temp-15.0.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-Temp-20.0.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-CapacityTimeHours.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-CapacityTime.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-Energy.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-PowerLoadTime.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-TripCurrent.png)
%20Ebay/Samsung%20INR18650-25R%202500mAh%20(Cyan)%20Ebay-Charge.png)
Conclusion
The battery has less capacity and can deliver less current than a real Samsung INR18650-25, but is not as such a bad cell.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
