Sanyo UR18650ZY 2600mAh (Red)
/DSC_9854.jpg)
Official specifications:
- Rated capacity min.: 2450mAh
- Capacity: Min. 2500mAh, Typ. 2600mAh
- Nominal voltage: 3.7V
- Charging: CC-CV, Std. 1750mA, 4.20V, 3.0 hrs.
- Weight Max.: 48.0g
- Temperature: Charge: 0 to +45°C, Discharge -20 to +60°C, Storage: -20 to +50°C
/Sanyo%20UR18650ZY%202600mAh%20(Red)-info.png)
This cell is some years old (Datasheet from 2012) and capacity and current is not very impressive by todays standard,
/DSC_9853.jpg)
/DSC_9856.jpg)
/DSC_9857.jpg)
/DSC_9858.jpg)
/DSC_9859.jpg)
/Sanyo%20UR18650ZY%202600mAh%20(Red)-Capacity.png)
The discharge curve looks good, the two cells tracks nicely and capacity is fairly constant with load.
/Sanyo%20UR18650ZY%202600mAh%20(Red)-CapacityTimeHours.png)
/Sanyo%20UR18650ZY%202600mAh%20(Red)-CapacityTime.png)
/Sanyo%20UR18650ZY%202600mAh%20(Red)-Energy.png)
/Sanyo%20UR18650ZY%202600mAh%20(Red)-PowerLoadTime.png)
/Sanyo%20UR18650ZY%202600mAh%20(Red)-TripCurrent.png)
/Sanyo%20UR18650ZY%202600mAh%20(Red)-Charge.png)
Conclusion
Being old style non-IMR 2600mAh cells they do have a fairly high voltage during discharge, in some applications this is an advantage compared to the newer 2900+mAh cells (This advantage is also shared with the 4.3(5) volt cells).
It is a very good cell.
Notes and links
Compare to 18650 and other batteries
