Sibeile IMR18350 700mAh ft (Black) 2014
%202014/DSC_4533.jpg)
Official specifications:
- Type: Lithium-ion rechargeable battery
- Nominal voltage: 3.7 V
- Nominal capacity: 700mAh
- Charging method: charge with constant current 1C to 4.2V, then charge with constant voltage 4.2V till charge current is less than 0.01C
- Operating environment: Charging, 0°C ~ 45°C ; 65±20%RH, Discharging, -20°C~60°C ; 65±20%RH
- Storage environment: -20°C~45°C 65±20%RH
- storage for a long time(>3 months) and the storage condition shall be:<35°C;65±20%RH;3.7~3.9V
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-info.png)
This is unprotected high current cells.
%202014/DSC_4519.jpg)
%202014/DSC_4535.jpg)
%202014/DSC_4536.jpg)
%202014/DSC_4537.jpg)
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-Capacity.png)
The batteries does track fairly well and can deliver a lot of current. The are very close to rated capacity, even at high current.
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-CapacityTimeHours.png)
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-CapacityTime.png)
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-Energy.png)
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-PowerLoadTime.png)
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-TripCurrent.png)
%202014/Sibeile%20IMR18350%20700mAh%20ft%20(Black)%202014-Charge.png)
Conclusion
These IMR batteries has good performance and I will rate them acceptable.
Notes and links
Comparison to other LiIon batteries
