Sibeile IMR18500 1100mAh (Black)
Official specifications:
- Capacity Nominal 1100 mAh
- Dimensions: - Diameter 18+/- 0.2 mm- Height 68+/- 0.2mm -Weight (Typical) Approx. 46 g yes
- Nominal Voltage: Average 3.7V
- Cut-off Voltage: 3.0V
- Internal Impedance: less or equal to 180 milliohm (with PTC)
- Cycle Performance: 90% of initial capacity at 400 cycles
- Cycle life: > 500 cycles
- Charge: Current = 0.5C mA Voltage = 4.2 V End Current = 0.01 mA
- Discharge: Current = 0.5C mA End Voltage = 3.0V
- Max. Charging current: 1.5C ma
- Max. Discharging current 1.5C ma (for continuous discharge)
This battery has a fairly low current rating.
There is a significant different between the two cells, this is not very good.
Conclusion
Sibeile has been a bit unlucky with this cell, it is not anywhere near the quality of the other Sibeile cells I have tested. It can be used stand alone, but not in series.
Notes and links
