Soshine 18350 1000mAh (Black)
/DSC_5276.jpg)
Official specifications:
Battery Capacity (Mfg Rated): 1000 mAh
Battery Chemistry: Li-ion
Battery Feature: Rechargeable
Battery Form Factor: 18350
Battery Maximum Voltage: 4.2 V
Battery Rated Voltage: 3.7 V
Minimum capacity: 900mAh
Internal resistance: 80 milliohm
Standard charge current: 200mA
Fast charge current: 1000mA (1.2hrs)
/Soshine%2018350%201000mAh%20(Black)-info.png)
A 18350 with fairly good capacity from Soshine, the specified capacity and fast charge rate is a bit on the high side.
/DSC_5275.jpg)
/DSC_5278.jpg)
/DSC_5279.jpg)
/DSC_5280.jpg)
/DSC_5281.jpg)
/Soshine%2018350%201000mAh%20(Black)-Capacity.png)
The curves matches fairly well and the cell can easily handle 3A.
/Soshine%2018350%201000mAh%20(Black)-Temp-3.0.png)
/Soshine%2018350%201000mAh%20(Black)-Temp-5.0.png)
/Soshine%2018350%201000mAh%20(Black)-Temp-7.0.png)
/Soshine%2018350%201000mAh%20(Black)-CapacityTimeHours.png)
/Soshine%2018350%201000mAh%20(Black)-CapacityTime.png)
/Soshine%2018350%201000mAh%20(Black)-Energy.png)
/Soshine%2018350%201000mAh%20(Black)-PowerLoadTime.png)
/Soshine%2018350%201000mAh%20(Black)-TripCurrent.png)
/Soshine%2018350%201000mAh%20(Black)-Charge.png)
Conclusion
The cell has fairly good capacity and is not a high current cell.
Performance is good, but there are cells with either more capacity or higher current.
Notes and links
Comparison to other LiIon batteries
