Maximum temperature raise at different discharge currents: 1A:+0,0°C, 2A:+1,0°C, 3A:+2,1°C, 5A:+5,4°C, 7A:+9,0°C, 10A:+13,2°C, 15A:+18,8°C, 20A:+20,1°C
The NiMH C cell from Soshine.
These two cells do not match capacity and are below rated capacity, at least the mismatch in capacity is only a minor problem with NiMH.
Conclusion
The batteries have a good capacity, but not as much as promised.
I bought 8 of these a couple months ago to use in a 4C LED motion activated hall light. I got a couple of these lights (Dorcy) years ago based on good results with the brand and the expectation that 4C would go a long time between charges. Not so. It’s a good light but VERY inefficient. With 2000mAh Sanyo I get a little over a week. With Tenergy Centura 4000mAh I get ~ 2 weeks.
With the Soshine I got pretty much the same results as HKJ with capacity testing….BUT, to start the batteries only lasted a few days! What? Not sure what the deal was. As I keep using them and accumulate more cycles they are performing better and are now lasting slightly over 2 weeks. Measured capacity has not improved much. Maybe old stock that needed a good workout? They are OK but fall short of spec.
