Tensai LC18350 950mAh (Gray)
/DSC_5678.jpg)
Official specifications:
- Typical Capacity: 900mAh
- Minimal Capacity: 850mAh
- Rated Voltage: 3.7 V
- Internal Resistance: 60 m
- Charge Voltage: 4.20V ±0.5
- Charge Mode: CC/CV
- Charge Time: Standard Charge Method: 8.0h (C/8), Quick Charge Method: 1h (1C)
- Continuous Discharge: 1C
- Max. Continuous Discharge Current: 3C
- Discharge Cut-off Voltage 3.0V
- Working Temperature: charge 0°C ~ 45°C, discharge -20°C ~ 60°C
- Storage Temperature -20°C ~ 35°C
- Battery Weight 22 ± 2g
/Tensai%20LC18350%20950mAh%20(Gray)-info.png)
A 18350 cell with decent current capability.
/DSC_5690.jpg)
/DSC_5680.jpg)
/DSC_5681.jpg)
/DSC_5682.jpg)
/Tensai%20LC18350%20950mAh%20(Gray)-Capacity.png)
The discharge curves looks fine, with good tracking and little capacity drop due to load.
/Tensai%20LC18350%20950mAh%20(Gray)-CapacityTimeHours.png)
/Tensai%20LC18350%20950mAh%20(Gray)-CapacityTime.png)
/Tensai%20LC18350%20950mAh%20(Gray)-Energy.png)
/Tensai%20LC18350%20950mAh%20(Gray)-PowerLoadTime.png)
/Tensai%20LC18350%20950mAh%20(Gray)-TripCurrent.png)
/Tensai%20LC18350%20950mAh%20(Gray)-Charge.png)
Conclusion
This cell is not the 18350 with highest current capability or highest capacity, but a good compromise.
I will rate this as an acceptable cell.
Notes and links
Comparison to other LiIon batteries
