Test/Review of Tensai plus AA TR-6H 2500mAh (White)
Official specifications:
  • Model: TR-6H (single cell) / 4TR-6H (4pcs blister pack)
  • Manufacturer: TENSAI
  • Size: AA, LR6
  • Chemistry: NiMH (Nickel Metal hydride)
  • Nominal Voltage: 1.2V
  • Capacity: Minimum: 2400mAh, Typical: 2500mAh, When discharged at 0.2C to 1.0V at 20°C
  • Fast Charge: up to 1200mA
  • Service Life: >500 cycles
  • Internal Resistance: <50mOhm (upon fully charged)
  • Diameter (mm): 14.5
  • Height (mm): 50.5
  • Weight: 29g
Maximum temperature raise at different discharge currents: 1A:+2,2°C, 2A:+5,6°C, 3A:+9,2°C, 5A:+16,9°C
A high capacity NiMH cell.
The cell does fine at low loads, but when the current reaches a couple of amperes it has problems.
Being a NiMH cell the capacity differences between the two tested cells is only a minor problem.
Conclusion
The cell has the rated capacity and acceptable performance.
Notes and links
The batteries was supplied by ENERDan for review.
Thanks for the review. Seems like they aren’t LSD, are they?
No, they are not.
Tensai does also have LSD batteries, I will post them at a later date.
Thanks, looking forward to reading about them. Your reviews are very useful! Your effort is appreciated
