TLife 18650A Protected 2200mAh (Green)
Button top and flat top protected TLife 2200mAh cells.
TLife 18650A BT Protected 2200mAh (Green)
Official specifications:
Model: 18650A
Battery Type: Lithium-ion
Rechargeable: Yes
Protected: Yes
Positive terminal style: Button-top
Nominal voltage: 3.7V
Discharge end voltage: 2.75V
Charging voltage: 4.20 +/- 0.03 V
Standard charging current: 1.625 A
Nominal capacity: 2200mAh
Rated capacity (minimum): 2100mAh
Dimensions: (2.77 x 0.72)” / (7.04 x 1.84)cm (L x Dia.)
Color: Green
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-info.png)
This is a low capacity, low current cell. Tmart has this cell in four configurations, this is the protected button top.
/DSC_6549.jpg)
/DSC_6551.jpg)
/DSC_6552.jpg)
/DSC_6553.jpg)
/DSC_6554.jpg)
/DSC_6555.jpg)
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Capacity.png)
The protection limits the current from this cell to less than 3A, the curves looks good enough.
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Temp-2.0.png)
With this low current there are absolutely no temperature problems.
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Temp-3.0.png)
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-CapacityTimeHours.png)
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-CapacityTime.png)
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Energy.png)
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-PowerLoadTime.png)
Due to the low protection threshold the battery cannot drive a 10W light.
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-TripCurrent.png)
/TLife%2018650A%20BT%20Protected%202200mAh%20(Green)-Charge.png)
TLife 18650A FT Protected 2200mAh (Green)
/DSC_6536.jpg)
Model: 18650A
Rechargeable: Yes
Protected: Yes
Positive terminal style: flattop
Dimensions: (2.73 x 0.72)” / (6.94 x 1.84)cm (L x Dia.)
Color: Green
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-info.png)
This is a low capacity, low current cell. Tmart has this cell in four configurations, this is the protected flat top.
/DSC_6535.jpg)
/DSC_6537.jpg)
/DSC_6538.jpg)
/DSC_6539.jpg)
/DSC_6540.jpg)
/DSC_6541.jpg)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Capacity.png)
Something is wrong here, a 2500mAh battery has sneaked into the 2200mAh collection of 2200mAh batteries. This makes me doubt the quality control.
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Temp-2.0.png)
Both types of batteries handles stays cool.
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Temp-3.0.png)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-CapacityTimeHours.png)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-CapacityTime.png)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Energy.png)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-PowerLoadTime.png)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-TripCurrent.png)
/TLife%2018650A%20FT%20Protected%202200mAh%20(Green)-Charge.png)
Conclusion
Due to the low protection threshold these cells are not for 1000 lumen flashlights, but only for equipment with a very moderate current consumption.
Generally these batteries has looked acceptable, but the 2500mAh cell is strange.
Notes and links
The batteries was supplied by TMart.com for a review.
Compare to 18650 and other batteries
