Turnigy Sub-C 5000mAh (Gray)
/DSC_4611.jpg)
Official specifications:
Category: Sub-C
Capacity: 5000mAh
Discharge: 10C constant / 15C burst
Voltage: 1.2V
Chemistry: Ni-MH rechargeable
Weight: 70g
Dimensions: 44x23x23mm
/Turnigy%20Sub-C%205000mAh%20(Gray)-info.png)
Maximum temperature raise at different discharge currents: 1A:+0,3°C, 2A:+1,0°C, 3A:+1,8°C, 5A:+3,9°C, 7A:+5,9°C, 10A:+8,4°C, 15A:+12,8°C, 20A:+16,4°C
This is a rather unknown battery size for many people. It is used for a lot of stuff, mostly battery packs, but may also be used inside regular C or D cell of the low capacity types. These cells are delivered with tabs, making it easier to use the for packs without a battery welder.
/DSC_4608.jpg)
/DSC_4616.jpg)
/DSC_4612.jpg)
/DSC_4613.jpg)
/DSC_4614.jpg)
/Turnigy%20Sub-C%205000mAh%20(Gray)-Capacity.png)
The cells do not match completely, this is not a serious problem with NiMH, the capacity specifications may also be a bit on the high side.
/Turnigy%20Sub-C%205000mAh%20(Gray)-CapacityTime.png)
/Turnigy%20Sub-C%205000mAh%20(Gray)-CapacityTimeHours.png)
/Turnigy%20Sub-C%205000mAh%20(Gray)-Energy.png)
/Turnigy%20Sub-C%205000mAh%20(Gray)-PowerLoadTime.png)
/Turnigy%20Sub-C%205000mAh%20(Gray)-CurrentTest.png)
/Turnigy%20Sub-C%205000mAh%20(Gray)-Charge.png)
Conclusion
The cells are rated for high capacity and current, these ratings may be a bit optimistic, but they have fairly high capacity and can deliver a lot of current.
Notes and links
The batteries was supplied by batteridoktorn.se for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
