UltraFire 16340 1000mAh (Blue)
Official specifications:
Battery Capacity (Mfg Rated): 1000 mAh
Battery Chemistry: Lithium
Battery Feature: Protected Rechargeable
Battery Form Factor: 16340
Battery Rated Voltage: 3.6 V
Brand: UltraFire
SKU: 1055500
/UltraFire%2016340%201000mAh%20(Blue)-info.png)
A 16340 from a cheap and often low quality brand with a record capacity according to the marking.
/DSC_4461.jpg)
/DSC_4462.jpg)
/DSC_4464.jpg)
/DSC_4465.jpg)
/DSC_4466.jpg)
/DSC_4467.jpg)
/DSC_4468.jpg)
/UltraFire%2016340%201000mAh%20(Blue)-Capacity.png)
The curves do not track perfectly, but not that bad either. The battery can deliver 1A, but definitly not 2A.
/UltraFire%2016340%201000mAh%20(Blue)-Temp-1.0.png)
/UltraFire%2016340%201000mAh%20(Blue)-Temp-2.0.png)
This small cell do not heat much up, even when overloaded.
/UltraFire%2016340%201000mAh%20(Blue)-CapacityTimeHours.png)
/UltraFire%2016340%201000mAh%20(Blue)-CapacityTime.png)
/UltraFire%2016340%201000mAh%20(Blue)-Energy.png)
/UltraFire%2016340%201000mAh%20(Blue)-PowerLoadTime.png)
/UltraFire%2016340%201000mAh%20(Blue)-TripCurrent.png)
/UltraFire%2016340%201000mAh%20(Blue)-Charge.png)
Conclusion
The rated capacity is nowhere near the real capacity. The capacity is a bit below a quality battery at low load and the difference increases with load.
Notes and links
Comparison to other LiIon batteries
