USB Load resistor 1A-2A
Official specifications:
Color: Green.
Resistance: 1A, 2A
Size: approx. 80 *18*11mm
when the switch adjust to 1A, the green LED light (There is no green led or dual color led)
when the switch adjust to 2A, the red LED light
I bought from ebay dealer: finetech007
The most interesting detail about this type of load is how hot they get, some power resistor has a working temperature between 200°C and 300°C when fully loaded.
This type of load is very simple, two big power resistors, one permanently connected, the other controlled by the switch and a led to show if there is any power supplied to it.
Load testing
This type of load is only designed for 5V input.
Current change during 30 minutes with 1A load is 0.013A, i.e. 1.3%
Current change during 30 minutes with 2A load is 0.029A, i.e. 1.5%
Being a resistor the current will depend on voltage.
As expected the load current and power is stable with a resistor, except for a small drop due to temperature.
M1: 74,2°C, M2: 99,2°C, M3: 70,8°C, HS1: 213,5°C
One resistor gets fairly hot.
M1: 66,0°C, M2: 69,3°C, HS1: 112,4°C
The tinned area on the back will equalize the temperature, but do not really radiate any heat.
M1: 255,9°C, M2: 253,5°C, M3: 139,1°C, M4: 115,7°C, HS1: 275,6°C
Two power resistor this close will heat each other and gets very hot.
The correct way to mount power resistors is a bit above the board with some distance between. These resistors are only running at half their rated power, but they cannot get rid of the heat.
M1: 100,3°C, M2: 101,7°C, HS1: 160,1°C
Again the radiation from the backside is limited.
Conclusion
The load works as expected and is an easy way to test usb power banks (together with a usb meter), but this model really need an external fan to supply lots of cool air.
It is a very bad idea to touch it when it is working.
Notes
Expect very similar performance from all resistive loads with two round green 10W 5ohm resistors.
