USB Load resistor 1A-2A usb output (Discharger3)
Official specifications:
USB male load 1A / 2A switch selection
10W 5R cement resistor, no odor
PHR foot switch selection 1A or 2A
I bought from ebay dealer: trade021
The most interesting detail about this type of load is how hot they get, some power resistor has a working temperature between 200°C and 300°C when fully loaded.
This type of load is very simple, two big power resistors, one permanently connected, the other controlled by the switch and a led to show if there is any power supplied to it.
I cannot guess what the purpose of the usb output is, adding more load is not really necessary.
Load testing
This type of load is only designed for 5V input.
Current change during 30 minutes with 1A load is 0.009A, i.e. 0.9%
Current change during 30 minutes with 2A load is 0.028A, i.e. 1.4%
The usb output has a working data connection to the input.
Being a resistor the current will depend on voltage.
As expected the load current and power is stable with a resistor, except for a small change due to temperature.
M1: 56,7°C, M2: 65,8°C, M3: 84,0°C, HS1: 156,1°C
One resistor gets fairly hot.
M1: 73,7°C, M2: 53,8°C, M3: 44,4°C, HS1: 149,4°C
The backside of the circuit board is also hot and is helping radiating the heat.
M1: 190,7°C, M2: 153,5°C, M3: 94,1°C, M4: 87,8°C, HS1: 204,5°C
With both resistors active they get rather hot, because they are heating each other.
The correct way to mount power resistors is a bit above the board with some distance between. These resistors are only running at half their rated power, but they cannot get rid of the heat.
M1: 73,3°C, M2: 60,0°C, M3: 86,5°C, M4: 129,9°C, HS1: 225,3°C
Conclusion
The load works as expected and is an easy way to test usb power banks (together with a usb meter), but this model need an external fan to supply lots of cool air especially when both resistors are used.
It is not a good idea to touch it when it is working.
Notes
Expect very similar performance from all resistive loads with two white square 10W 5ohm resistors.
