USB Load resistor 1A
Official specifications:
Type: 1A discharge resistor.
Used For: Power bank / Battery Capacity testing.
Brand new and high quality.
I bought it on ebay some time ago.
The most interesting detail about this type of load is how hot they get, some power resistor has a working temperature between 200°C and 300°C when fully loaded.
This type of load is very simple, two big power resistors and a led to show if there is any power supplied to it.
Load testing
This type of load is only designed for 5V input.
Current change during 30 minutes with 1A load is 0.005A, i.e. 0.5%
Being a resistor the current will depend on voltage.
As expected the load current and power is stable with a resistor, except for a small drop due to temperature.
M1: 165,5°C, M2: 87,0°C, M3: 57,4°C, M4: 171,9°C, HS1: 181,2°C
The resistors gets fairly hot.
The correct way to mount power resistors is a bit above the board with some distance between. These resistors are only running at half their rated power, but they cannot get rid of the heat.
M1: 124,5°C, M2: 63,8°C, HS1: 132,1°C
Conclusion
The load works as expected and is an easy way to test usb power banks (together with a usb meter), but this model need an external fan to supply lots of cool air.
It is a bad idea to touch it when it is working.
Notes
Expect very similar performance from all resistive loads with two square white 5W 10ohm resistors.
