Test/review of Usb travel charger 1A
Official specifications:
  • Input: 100-240VAC
  • Output: 5V 1000mA
I got it from a Ebay dealer: ibo_store with help from a reader.
Measurements
  • Power consumption when idle is 0.13 watt
  • USB output is coded as Apple 2.1A
  • Weight: 19.2g
  • Size: 66.7 x 35 x 14.2mm
The charger can deliver about 1.26A before overload protection trips, this is fine.
The current is slightly lower at 120VAC.
No problems running one hour at 1A.
M1: 65,0°C, M2: 43,4°C, HS1: 66,3°C
M1: 64,9°C, M2: 46,5°C, HS1: 65,0°C
M1: 61,3°C, HS1: 64,0°C
M1: 50,6°C, HS1: 53,9°C
M1: 60,9°C, HS1: 62,9°C
At 0.5A the noise is 87mV rms and 935mVpp.
At 1A the noise is 115mV rms and 1068mVpp, this is a rather high noise.
Tear down
This adapter was easy to open, I did not need any tools, I just had to break the pins a bit and it popped open.
Fairly compact construction. At the mains input is a fusible resistor and a bridge rectifier. The mains switchers is below the 6.8uF black capacitor. Besides the transformer is a “safety” capacitor and beside the usb connector is a rectifier diode and some resistors for coding.
The bridge rectifier is close to the mains input “L”
The blue capacitor is not a safety capacitor, but just a regular 1kV capacitor, this is not acceptable or safe.
No parts on this side.
Distance between mains and low volt side must be 4mm through air, this is not the case between the black and green capacitor. Some yellow tape around the black capacitor could have fixed that.
On the circuit board the distance must be 6.4mm and here it is 3mm, not good enough.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger is made to look like an Apple model, but the performance and safety is not very good
Notes
How does a usb charger work?
Thanks for the review!. Seems like it’s got rather hi noise.
Yes, but what immediately kills the deal is the non-safety capacitor. If it fails the charger will have mains on the usb connector (A fridge that turns off may make it fail)!
The difference between safety and non-safety capacitors is the way they fail: A safety capacitor will loose capacity, but keep the isolation, a non-safety capacitor may short.
Oh! Thanks for the clarification. I didn’t realize how dangerous it could be!! :frowning:
Have been wondering for some time, where do the 2830 volt and 4242 volt numbers come from? Which specific regulation?
ISO60950-1, the actual voltages is 2000VAC and 3000VAC, but they can be changed to DC voltage for testing by multiplying with sqrt(2).
