Vapcell ICR18500 2000mAh (Green) 2018
%202018/DSC_4728.jpg)
Official specifications:
Model: ICR18500
Type: Flat top
Nominal voltage: 3.60V
End-of-charge voltage:4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 2000mAh (0.2C discharge)
Min capacity: 1950mAh (0.2C discharge)
Weight: Max:35g
Internal resistance: Max:50mOhm (AC 1kHz)
Standard Charge: 1000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 1500mA
Max Continuous Discharge Current: 5A
Operating Temperature: Charging, 0°C ~ 45°C, Discharging, –20°C ~ 75°C
Storage Temperature –5°C ~ 35°C
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-info.png)
This is one of the less used sizes, this battery is not a high current cell.
%202018/DSC_4727.jpg)
%202018/DSC_4730.jpg)
%202018/DSC_4731.jpg)
%202018/DSC_4732.jpg)
%202018/DSC_4733.jpg)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-Capacity.png)
The discharge curves tracks fairly well and it can deliver the rated 5A, but definitely not 10A.
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-Temp-5.0.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-Temp-7.0.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-Temp-10.0.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-CapacityTimeHours.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-CapacityTime.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-Energy.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-PowerLoadTime.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-TripCurrent.png)
%202018/Vapcell%20ICR18500%202000mAh%20(Green)%202018-Charge.png)
Conclusion
The battery looks good, but with the size and 5A limit its applications are limited.
Notes and links
This size battery matches 3 CR123 primary batteries in length and voltage, but is larger in diameter.
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
