I understand that “low/mid/high-drain” on batteries are probably relative to the type of battery.
So that for 18650’s, usually 8-10A is “medium-drain”, 5A is “low-drain”, and 15A or higher is “high-drain” (from what I observed)…
For 14500 batteries, I usually see 2.5-3A for the more common 14500 battery types, and 7A for ‘high-drain’ 14500 batteries. So maybe 2.5-3A is considered ‘medium-drain’ for 14500 batteries?
(how about for 21700 batteries, 10A seems to be ‘low-drain’ for them, since 15A is more common for 21700, so probably that’s ‘medium-drain’ 21700, while ‘high-drain’ 21700s could be more than 20A rating?)
It is better to look at it compared to capacity.
Below 1C is low drain.
Above 3C is starting on high drain, some cells can go up to 10C.
C is the capacity of the battery, but here read as current.
so giving some samples:
1000mAh 14500:
3C = 3A (I notice many 14500 batteries have 2.5-3A rating, so it seems "common")
5C = 5A (these rating would be a bit rarer for 14500 batteries)
3000mAh 18650:
3C = 9A (I used to think the 3500mAh Samsung 35E / Sanyo NCR18650GA / LG MJ1, rated at 8-10 Amps are just considered "medium-drain')
5C = 15A (now 15A seems to be high-drain for 18650s..)
4000mAh 21700:
3C = 12A (12A seems to be common for 21700 batteries?)
5C = 20A (now 20A would be a good drain rating for 21700)
5000mAh 26650:
3C = 15A
4C = 20A
5C = 25A
maybe 4-5C to consider as high-drain could be better?
anyway, just my random thoughts..
I said that high drain is staring at 3C. Originally standard LiIon batteries (ICR) was rated 2C and when you got above that (i.e. 3C) it was high drain. That limit is on the low side for todays batteries as you say.
