Vapcell INR18650 2000mAh (Black)
/DSC_2071.jpg)
Official specifications:
Model: vapcell INR18650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50v
Typical Capacity: 2000mAh (0.2C discharge)
Min capacity: 1950mAh (0.2C discharge)
Weight: Max:48g
Internal resistance: Max:8mOhm
Standard Charge: 1000mA,CCCV 100mA cut-off
Charging Time: 3 hours (standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 38000mA
Operating Temperature: Charging, 0°C ~ 45°C, Discharging, –20°C~75°C, Storage Temperature-5°C~35°C
Storage Humidity: <75%RH
Appearance: Without scratch, distorion, contamination and leakage
Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH, Atmospheric Pressure: 86-106KPA
/Vapcell%20INR18650%202000mAh%20(Black)-info.png)
This is a low capacity 18650 cell that can handle very high current.
/DSC_2070.jpg)
Very nice box for the batteries, especially if you want to carry spare batteries. The one I got include a paper with the above specifications.
/DSC_2073.jpg)
/DSC_2074.jpg)
/DSC_2075.jpg)
/DSC_2076.jpg)
/Vapcell%20INR18650%202000mAh%20(Black)-Capacity.png)
This is a good looking discharge chart, the cells tracks perfectly and capacity is nearly constant up to (and probably a bit above) 30A
/Vapcell%20INR18650%202000mAh%20(Black)-Temp-15.0.png)
/Vapcell%20INR18650%202000mAh%20(Black)-Temp-20.0.png)
/Vapcell%20INR18650%202000mAh%20(Black)-Temp-30.0.png)
The battery gets warm at 30A, but could handle more current before the temperature would be a problem.
/Vapcell%20INR18650%202000mAh%20(Black)-CapacityTimeHours.png)
/Vapcell%20INR18650%202000mAh%20(Black)-CapacityTime.png)
/Vapcell%20INR18650%202000mAh%20(Black)-Energy.png)
/Vapcell%20INR18650%202000mAh%20(Black)-PowerLoadTime.png)
/Vapcell%20INR18650%202000mAh%20(Black)-TripCurrent.png)
/Vapcell%20INR18650%202000mAh%20(Black)-Charge.png)
Conclusion
For people that want to play with high current, i.e. 20A, 30A or more this looks like a very interesting cell. But the price is a fairly low capacity.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
