Vapcell INR18650 2500mAh K25 (Red) 2020
Official specifications:
Model: K25 INR18650 2500mah 20A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 2500mAh (0.2C discharge)
Min capacity: 2400mAh (0.2C discharge)
Weight: Max:46g
Internal resistance: Max:15m? ?AC 1kHz?
Standard Charge: 2000mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 20A
Max Discharge Current: 35A
High current 18650 batteries with moderate capacity.
The two cells match nicely and can deliver 15A continuous, at higher current I stop test early due to temperature.
Conclusion
These batteries is not super high current, but can deliver a good current. The capacity is on pair with many high current 18650 cells and not that high.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
