Vapcell INR18650 2600mAh (Green) 2018
%202018/DSC_3258.jpg)
Official specifications:
Model: INR18650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 2600mAh (0.2C discharge)
Min capacity: 2500Ah (0.2C discharge)
Weight: Max:48g
Internal resistance: Max:12mOhm (AC 1kHz)
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 1.5hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 25A
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-info.png)
This is a high current 18650 cell from Vapcell and with the lower capacity it usual means it is good at high current.
%202018/DSC_3257.jpg)
%202018/DSC_3260.jpg)
%202018/DSC_3261.jpg)
%202018/DSC_3262.jpg)
%202018/DSC_3263.jpg)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-Capacity.png)
The discharge curves tracks nicely and the cell can deliver 30A with about the same capacity
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-Temp-15.0.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-Temp-20.0.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-Temp-30.0.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-CapacityTimeHours.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-CapacityTime.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-Energy.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-PowerLoadTime.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-TripCurrent.png)
%202018/Vapcell%20INR18650%202600mAh%20(Green)%202018-Charge.png)
Conclusion
This is a good high current battery and it can deliver a lot of current and like all high current batteries there is a trade-off in capacity.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
