Vapcell INR18650 2600mAh (Yellow)
/DSC_5539.jpg)
Official specifications:
Model: INR18650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 2600mAh (0.2C discharge)
Min capacity: 2500mAh (0.2C discharge)
Weight: Max:48g
Internal resistance: Max:14mOhm
Standard Charge: 1500mA,CCCV 100mA cut-off
Charging Time: 2.5hours(standard charge)
Quick Charge Current: 3000mA
Max Continuous Discharge Current: 20000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
/Vapcell%20INR18650%202600mAh%20(Yellow)-info.png)
This is fairly high current batteries with acceptable capacity.
/DSC_5541.jpg)
/DSC_5542.jpg)
/DSC_5543.jpg)
/DSC_5544.jpg)
/Vapcell%20INR18650%202600mAh%20(Yellow)-Capacity.png)
There is a small capacity difference between the two batteries, they do not like very high current discharge (30A)
/Vapcell%20INR18650%202600mAh%20(Yellow)-Temp-10.0.png)
/Vapcell%20INR18650%202600mAh%20(Yellow)-Temp-15.0.png)
Something went wrong with the A cell for this test, it was fully charged, but the discharge was skipped.
/Vapcell%20INR18650%202600mAh%20(Yellow)-Temp-20.0.png)
I wonder about the temperature difference, maybe I forgot to place the sensor on the B cell, but it must have been close.
/Vapcell%20INR18650%202600mAh%20(Yellow)-CapacityTimeHours.png)
/Vapcell%20INR18650%202600mAh%20(Yellow)-CapacityTime.png)
/Vapcell%20INR18650%202600mAh%20(Yellow)-Energy.png)
/Vapcell%20INR18650%202600mAh%20(Yellow)-PowerLoadTime.png)
/Vapcell%20INR18650%202600mAh%20(Yellow)-TripCurrent.png)
/Vapcell%20INR18650%202600mAh%20(Yellow)-Charge.png)
Conclusion
The batteries handles 15A fine, but 20A is at the limit. Performance is as expected from a high current battery.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
