Vapcell INR18650 3000mAh P1830A (Black-green) 2020
%202020/DSC_4150.jpg)
Official specifications:
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2950mAh (0.2C discharge)
Weight: Max:50g
Internal resistance: Max:23mOhm (AC 1kHz)
Standard Charge: 1500mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 15000mA (15A)
Operating Temperature: Charging, 0°C ~ 45°C
Operating Temperature: Discharging, –20°C ~ 70°C
Storage Temperature: –5°C ~ 35°C
Over charge protection voltage: 4.25+0.05/-0V
Over discharge protection voltage: 2.50+0/-0.05V
Over current protection current: 17A ~ 20A
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-info.png)
This is a protected 3000mAh 18650 battery that can deliver a fair amount of current.
%202020/DSC_4149.jpg)
%202020/DSC_4152.jpg)
%202020/DSC_4153.jpg)
%202020/DSC_4154.jpg)
%202020/DSC_4155.jpg)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-Capacity.png)
The two cells match nicely.
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-Temp-7.0.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-Temp-10.0.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-Temp-15.0.png)
I stopped this discharge due to temperature.
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-CapacityTimeHours.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-CapacityTime.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-Energy.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-PowerLoadTime.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-TripCurrent.png)
%202020/Vapcell%20INR18650%203000mAh%20P1830A%20(Black-green)%202020-Charge.png)
Conclusion
The batteries looks fine.
The over current protection will not protect against a the battery getting too warm, only against gross overloads (This is fairly common).
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
