Vapcell INR18650 3500mAh P1835A (Black-orange) 2020
Official specifications:
Nominal voltage: 3.60V
End-of-charge voltage 4.20V
End-of-discharge voltage: 2.50V
Typical capacity: 3500mAh
Minimum capacity: 3350mAh
Internal resistance: Max 35mOhm AC 1kHz
Standard charge current: 1500mA CCCV 100mA cut-off
Quick charge: 3000mA CCCV 100mA cut-off
Fast discharge current: 8000mA
Max continuous discharge: 10A
USB input power: 5V 1A
USB CC charge current: 750mA
Over discharge protection: 2.5V +0.05V/-0V
Over charge protection: 4.25V +0V/-0.05V
Over current protection: 12A ~ 15A
This is a high capacity 18650 cell with build-in USB charger.
%202020/DSC_3477.jpg)
%202020/DSC_3479.jpg)
%202020/DSC_3480.jpg)
%202020/DSC_3481.jpg)
%202020/DSC_3482.jpg)
%202020/DSC_3483.jpg)
%202020/DSC_3484.jpg)
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-Capacity.png)
The two cells matches very well and are best used at 7A or below.
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-Temp-10.0.png)
My temperature sensor needs a new battery as can be seen on the B curve.
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-CapacityTimeHours.png)
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-CapacityTime.png)
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-Energy.png)
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-PowerLoadTime.png)
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-TripCurrent.png)
%202020/Vapcell%20INR18650%203500mAh%20P1835A%20(Black-orange)%202020-Charge.png)
Charging from the USB input (The battery was not fully discharge that is the reason for only 2500mAh capacity).
Conclusion
For users with only a few cells or traveling users USB charging is a very nice options.
They look like good cells in this size.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
