Vapcell INR20700 3000mAh (Purple) 2018
%202018/DSC_3269.jpg)
Official specifications:
Model: INR20700
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2850Ah (0.2C discharge)
Weight: Max:60g
Internal resistance: Max:12mOhm
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-info.png)
A high current cell in the new 20700 format.
%202018/DSC_3265.jpg)
%202018/DSC_3271.jpg)
%202018/DSC_3272.jpg)
%202018/DSC_3273.jpg)
%202018/DSC_3274.jpg)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-Capacity.png)
The discharge curves tracks fairly well and the cells can handle 30A nicely.
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-Temp-20.0.png)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-Temp-30.0.png)
But they do get warm at 30A
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-CapacityTimeHours.png)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-CapacityTime.png)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-Energy.png)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-PowerLoadTime.png)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-TripCurrent.png)
%202018/Vapcell%20INR20700%203000mAh%20(Purple)%202018-Charge.png)
Conclusion
These cells are at the low end of capacity for 20700 cells, but instead they have a fairly good high current performance.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
