Vapcell NCR20700 3200mAh (Gold)
/DSC_2081.jpg)
Official specifications:
Model: NCR20700
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3200mAh (0.2C discharge)
Min capacity: 3100mAh (0.2C discharge)
Weight: Max:60g
Internal resistance: Max:10mOhm
Standard Charge: 2000mA,CCCV 50mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
/Vapcell%20NCR20700%203200mAh%20(Gold)-info.png)
A high current cell of the new 20700 size.
/DSC_2080.jpg)
/DSC_2083.jpg)
/DSC_2084.jpg)
/DSC_2085.jpg)
/DSC_2086.jpg)
/Vapcell%20NCR20700%203200mAh%20(Gold)-Capacity.png)
The discharge curve is very good, it tracks nearly perfectly and the capacity do not drop much with loads up to 30A
/Vapcell%20NCR20700%203200mAh%20(Gold)-Temp-15.0.png)
A 30°C temperature raise at 15A, this is easy for the cell.
/Vapcell%20NCR20700%203200mAh%20(Gold)-Temp-30.0.png)
At 30A it gets fairly hot, but not too hot. 30A looks like a good rating for this cell.
/Vapcell%20NCR20700%203200mAh%20(Gold)-CapacityTimeHours.png)
/Vapcell%20NCR20700%203200mAh%20(Gold)-CapacityTime.png)
/Vapcell%20NCR20700%203200mAh%20(Gold)-Energy.png)
/Vapcell%20NCR20700%203200mAh%20(Gold)-PowerLoadTime.png)
/Vapcell%20NCR20700%203200mAh%20(Gold)-TripCurrent.png)
/Vapcell%20NCR20700%203200mAh%20(Gold)-Charge.png)
Conclusion
This battery do not have more capacity than 18650, but it handles high current better that the best 18650.
I will call this a very good cell.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
