Vappower INR20700 3000mAh (Green)
/DSC_5216.jpg)
Official specifications:
Nominal Voltage: 3.6v
Charging Voltage: 4.2v
Standard Charging: CC-CV, 1.25A, 4.2V±0.05, 50mA cut-off
Rapid Charging: CC-CV, 4A, 4.2V±0.05, 100mA cut-off
Capacity:3000mAh
Energy Density: Nom.240Wh/kg
Max. discharge current: 30A
Max. pulse discharge: 50A
Discharge cut-off voltage: 2.5V
Internal resistance:Max.20mOhm
Cell weight: 47G
/Vappower%20INR20700%203000mAh%20(Green)-info.png)
A high current 20700 battery.
/DSC_5215.jpg)
/DSC_5218.jpg)
/DSC_5219.jpg)
/DSC_5220.jpg)
/DSC_5221.jpg)
/Vappower%20INR20700%203000mAh%20(Green)-Capacity.png)
The discharge curves tracks fine and the cell has nearly constant capacity.
/Vappower%20INR20700%203000mAh%20(Green)-Temp-20.0.png)
The cell gets fairly warm at 20A
/Vappower%20INR20700%203000mAh%20(Green)-Temp-30.0.png)
And I had to stop the discharge at 30A
/Vappower%20INR20700%203000mAh%20(Green)-CapacityTimeHours.png)
/Vappower%20INR20700%203000mAh%20(Green)-CapacityTime.png)
/Vappower%20INR20700%203000mAh%20(Green)-Energy.png)
/Vappower%20INR20700%203000mAh%20(Green)-PowerLoadTime.png)
/Vappower%20INR20700%203000mAh%20(Green)-TripCurrent.png)
/Vappower%20INR20700%203000mAh%20(Green)-Charge.png)
Conclusion
This battery can deliver a lot of current with a good capacity, performance is about the same as the best 18650.
Notes and links
The battery was supplied by Vappower for review.
Compare to 18650 and other batteries
