VariCore 32700 LiFePO4 6500mAh (Gray)
Official specifications:
Model: 32700
Voltage: 3.2V
Nature: LiFePO4
Capacity: 6500mAh
Discharge current: 35A
Maximum current: 55A
Large LiFePO4 batteries with good capacity and high current rating.
/DSC_5341.jpg)
/DSC_5343.jpg)
/DSC_5344.jpg)
/DSC_5345.jpg)
/DSC_5346.jpg)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Capacity.png)
The two cells tracks fairly well and has no problem delivering 30A with nearly same capacity as at low current. As usual LiFePO4 has a very flat discharge curve.
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Temp-20.0.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Temp-30.0.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-CapacityTimeHours.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-CapacityTime.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Energy.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-PowerLoadTime.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-TripCurrent.png)
/VariCore%2032700%20LiFePO4%206500mAh%20(Gray)-Charge.png)
Conclusion
This looks like good batteries, they can deliver a lot of current and has fairly constant output voltage.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
