Xtar 14500 800mAh (Black)
/DSC_5301.jpg)
Official specifications:
- Capacity: 800mAh
- Nominal voltage: 3,7V
- Charge voltage: 4,2V +-0,05
- Discharge voltage: 2,5V
- Positive pole: Button top
- Protection circuit (BMS): yes
- Chemical composition: LiNiCoAlO2
- Diameter: 14,3mm ± 0,2
- Height: 50,5mm ± 0,5
- Weight:28g ± 1
- Charging method: CC-CV
/Xtar%2014500%20800mAh%20(Black)-info.png)
AA sized 3.7 volt LiIon battery from Xtar.
/DSC_5300.jpg)
/DSC_5303.jpg)
/DSC_5304.jpg)
/DSC_5305.jpg)
/Xtar%2014500%20800mAh%20(Black)-Capacity.png)
The two batteries tracks fairly well for 14500 batteries, but definitely not perfect. The capacity is 800mAh at low loads but drops at higher loads.
/Xtar%2014500%20800mAh%20(Black)-CapacityTimeHours.png)
/Xtar%2014500%20800mAh%20(Black)-CapacityTime.png)
/Xtar%2014500%20800mAh%20(Black)-Energy.png)
/Xtar%2014500%20800mAh%20(Black)-PowerLoadTime.png)
/Xtar%2014500%20800mAh%20(Black)-TripCurrent.png)
/Xtar%2014500%20800mAh%20(Black)-Charge.png)
Conclusion
The battery has an acceptable performance, but it is possible to find better performing battery (That are slightly longer).
Notes and links
Comparison to other LiIon batteries
