Xtar INR18650 2600mAh (Cyan) 2020
%202020/DSC_2971.jpg)
Official specifications:
Nominal capacity: 2600mAh
Nominal voltage: 3.6V
End of discharge voltage: 2.5V
Max. pulse discharge current: 35A
Max. continuous discharge current: 25A
Charging temperature range: 0°C ~ 60°C
Discharging temperature range: –40°C ~60°C
Cycle life: 500 cycles
Internal resistance <20mOhm
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-info.png)
This is high current cells with fairly low capacity.
%202020/DSC_2970.jpg)
%202020/DSC_2983.jpg)
%202020/DSC_2973.jpg)
%202020/DSC_2974.jpg)
%202020/DSC_2975.jpg)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Capacity.png)
The two cells do not match, the A cell has lower capacity and handles less current. I stop the test a bit early at high current due to the cell temperature.
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-10.0.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-15.0.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-20.0.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Temp-30.0.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-CapacityTimeHours.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-CapacityTime.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Energy.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-PowerLoadTime.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-TripCurrent.png)
%202020/Xtar%20INR18650%202600mAh%20(Cyan)%202020-Charge.png)
With these charge curves it looks like one of the cells are faulty.
Conclusion
One of the cells looks fairly good, the other do not.
This makes these cells a bad choice.
Notes and links
The batteries was supplied by Xtar for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
