Yojock USB-C PD 48W car charger S-SC-066
Official specifications:
Output Interface: USB
Type: Car Charger
USB Ports: 2
Power Source: Car Lighter Slot
Input: 12-24V/2.4A
Support Quick Charge Technology: USB PD,Qualcomm Quick Charge 2.0,Qualcomm Quick Charge 3.0
Output: 5V/3A
PD output port: DC 5V/3A,9V/2A,12v/2.5A 30 watt max
QC 3.0 output port: DC 5V/3A 9V/2A 12V/1.5A, 18 watt max
PD port also compatible with QC 3.0 and QC 2.0
PD 2.0 power delivery 30w usb type c car charger
I got it from Aliexpress dealer: YOJOCK Official Store
Behind the small hole is a blue led to show when socket is powered.
Measurements
PD codes: 5V 3A, 9V 3A, 12V 2.5A
PD outputs starts disabled.
PD output is coded as Apple 2.4A, DCP, QC2
QC support DCP, Apple 2.4A, QC3, Huwai-FCP, Samsung-AFC
Minimum QC3 voltage is 3.56V
Power consumption when idle is 12mA from 12V and 17mA from 24V
Both switchers works at around 150kHz
It is slightly too short for my test car outlet.
Power consumption when noting is connected to output depends on input voltage.
QC output
5V output with low input voltage, this looks good up to about 3.5A, this is fine for a 3A rated output.
9V output, the same 3.5A
12V output, again the same 3.5A, output is only rated for 1.5A. Output voltage is a bit low, because the input voltage is low and this charger do not have a boost converter.
12V output with high input voltage the output is maintained at 12V.
In these curves I sweep voltage from 24V and down with a output load of 2A, this one shows the input current with 5V output.
The 5V output is stable down to about 5.5V input.
9V output works below 10V input, the pulses around 6V is attempts to retrigger QC
12V output works down to about 12.5V input, the pulses around 10V is attempts to retrigger QC
At 5V 0.5A the noise is 3mV rms and 142mVpp
At 5V 1A the noise is 4mV rms and 152mVpp
At 5V 2.5A the noise is 134mV rms and 4mVpp
At 9V 0.9A the noise is 3mV rms and 156mVpp
At 12V 1.2A the noise is 6mV rms and 136mVpp.
PD output
USB-C PD with 5V output and high input voltage can deliver a little bit above 3A.
9V is also a bit above 3A.
Even 12V looks to be very close to 3A
12V output with low input voltage, as expected the output voltage is a bit low.
It can maintain 5V output down below 6V input.
For 9V output it need 10V input.
For 12V it need 13V input.
At 5V 0.5A the noise is 6mV rms and 124mVpp
At 5V 1A the noise is 3mV rms and 76mVpp
At 5V 2.5A the noise is 5mV rms and 106mVpp
QC and PD full load test
First test is at 5V 6A, i.e. rated load on both output, that was too much for the charger.
Reducing the current to 2.8A on both output fixed it and it could run a hour.
The temperature photo below are taken between 30 minutes and 60 minutes into the one hour test.
M1: 64.9°C, HS1: 75.9°C
M1: 60.8°C, HS1: 64.0°C
Tear down
I mounted it my vice and gave it a whack of my mallet and it was open.
On this side is one of the inductors.
Where the spring is connected is a fuse. Both switcher chips are below this inductor, there is a total of 3 chips. Probably 2xswitcher and one PD controller. Beside the usb-c connector is a transistor (Q3), it is probably used to turn off the usb-c voltage, until the chip sees a usb-c device that wants power.
Behind the usb-a connector is the QC and more chip.
Being a 12V device there is no need to test with high voltages.
Conclusion
The USB-A output supports all the common fast charge schemes, including Quick Charge.
The PD output support a few fast charge schemes in addition to PD.
The over current protection on PD is a bit to close to the 3A specification and prevented using it at full power.
It can deliver up to 12V on both ports with a fairly low voltage drop.
Notes
