Samsung ICR18650-28A 2800mAh (Purple)
/DSC_0041.jpg)
Official specifications:
- Place of origin : Samsung in Korea
- Capacity: 2800mAh
- Ultra-high capacity and premium built quality
- Unprotected
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-info.png)
This battery is not the usual 4.2 volt charging, but needs 4.3 volt charging, i.e. a special charger must be used (Some hobby chargers can be adjusted for it).
/DSC_0040.jpg)
/DSC_0043.jpg)
/DSC_0044.jpg)
/DSC_0045.jpg)
/DSC_0046.jpg)
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-Capacity.png)
The cell has a higher voltage than most other batteries.
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-CapacityTimeHours.png)
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-CapacityTime.png)
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-Energy.png)
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-PowerLoadTime.png)
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-TripCurrent.png)
%204.3V/Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-Charge.png)
Test with 4.2 volt charging
It is possible and perfectly safe to use this battery with 4.2 volt, but it will have less capacity.
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-info.png)
When only charging to 4.2 volt the battery looses about 220mAh in capacity.
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-Capacity.png)
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-CapacityTimeHours.png)
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-CapacityTime.png)
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-Energy.png)
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-PowerLoadTime.png)
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-TripCurrent.png)
/Samsung%20ICR18650-28A%202800mAh%20(Purple)-Charge.png)
Conclusion
That is a good cell, but the requirement for a special charger to get the full benefit of the battery, does reduce the usefulness of it. Using it with a 4.2 volt charger negates any benefit of the higher voltage and capacity.
Notes and links
