Anyhow , was a warm [ hot ] day today , and didnt feel like going anywhere , so decided to play indoors and discharge some AA batteries to see how they go ...
Now I had to drop the discharge rate to 200mAh in my Powerex to actually discharge the batteries cos the voltage sag was so brutal for the batteries and they would sag to the cut of voltage on the charger ...
Two batteries failed to discharge a single mAh cos of the Voltage sag ...
Ultracharge Dry Cell - Failed to discharge at even 100mAh rate - ran for 60 minutes in my N-light B2
Eveready blue - Failed to discharge at even 100mAh rate - ran for 75 minutes
Eveready red - 200mAh discharge rate = 126mAh - then ran for 70 minutes
Camelion - 200mAh discharge rate = 138mAh - then ran for 80min
Kodak - 200mAh D/R = 171mAh - 75min
Phillips - 200mAh D/R = 215mAh - 115min
Varta - 200mAh D/R = 1325mAh - 90min
Coles - 200mAh D/R = 1466mAh - 100min
Run time is calculated by putting the battery in my N-light B2 and running the cell down until the light begins to flicker [ very low output and battery is failing ]
Obviously the batteries simply cant be reliably discharged as the voltage drops so badly , so I thought I may as well run them to failure after doing the discharge to get a better picture .
Would be nice to drain every last drop of energy VIA the charger , but it was not going to happen ...
I will be doing more battery experiments as time permits ..
currently playing with the smaller 10440 , and doing some experiments with some really old rechargeable batteries [ resurrecting dead cells ] , interesting !
