I’m glad to see you make your own design, but unfortunately you can’t call it the “Texas_Ace” …… Integrating Sphere. You’ll have to use a different name like the Flashaholics Sphere or KG Tuning Sphere.
The one thing you still need is a calibrated reference light such as the one sold by Maukka. Now that I have mine, I plan to experiment with some ideas I have in my head.
I do see one flaw in your design, I think, and that is you have the light reflecting back almost 180° into the sensor tube. Matt at Adventure Sport Flashlights did this same thing. Ideally the light should bounce around in the box to become diffused. You might get more consistent readings if the flashlight opening was on the left side of the box in the picture firing over the top of the tube. This way you avoid direct reflections.
I can push the sensor tube all way in so the opening faces the roof but tbh the inlet diffuser is so thick the light is very linear. Readings are relative no matter where the sensor is. I can seal the hole and put it inside the box.
I’m wondering if making the insides of a pyramid design reflective and using the same inlet/outlet arrangement will be as accurate.
He’s not using a calibration light per se. He’s using his existing flashlights and assuming they have the same output as the ones that Maukka has measured in the past.
The hardest part about using a box is that you get reflections which doesn’t mix the light around as well as a sphere shape. If you have some extra styrofoam pieces I would add some baffles inside maybe in the corners to try and get the light to spread around as evenly as possible. Make sure that the light hitting the tube inlet is all ambiant light. You don’t want direct light hitting that diffuser disc.
If you did mount the tube and sensor completely inside you would need to make sure it didn’t move around or fall over. It would need to be fixed in a permanent position so that you get repeatability.
I’m using TA’s disks to block outside light, tbh I’m getting very similar readings to TA on my sub 6000 lumen lights, the Cometa is 200 odd fully zoomed!!! my X45, DX80 and X80 are right on what I thought but the X80-GT is reading phenomenally high, even on a system that may slightly favour throwers.
I hope Maukka tests it at some point. When sat on the diffusers it reads 12,000 lumens more than the X80 on my sphere and 10,000 more on TA’s sphere. So it’s undeniably comparatively bright.
I’ll post all readings tomorrow, I’m happy with them but 36,000 turn on lumens for the X80-GT is insane.
For the Cometa zoomie I get what I got on the TA tube: 200ish throw, 700ish flood. I’m seeing absolutely no hint of a beam or elevated readings to throwers. I’m using a thick dense polystyrene sheet that is cratered on the front and TA’s plastic diffuser in front of it to prevent melt issues.
I’ve got over 30 lights reading as expected but It’s bothering me why the X80-GT is reading so high. I think maybe the bounce back is responsible for the low readings on the Cometa, light reflecting back into a fairly dark deep reflectorless head. And the X80-GT is relatively flat…
So again I’m thinking a ceiling bounce is a more reliable way providing you have calibrated/trusted lights of differing beams.
I.e Acebeam rate the X45 at 16500, Maukka measured it at 14890, AKB measured it at 14820 and I measured it at 14500, several other reviewers measured it similar, so it should really be around 14.8k, now I apply the same logic to my other 30+ lights. I.e if a Calibrated system is giving me 14800 for the X45 then it should also return approx 4300 for the D4 XPL-HI an 900ish for the Olight S1R. Maukka got 890 for the S1R, I have 3 S1R’s/4 XPL-HI that all read roughly the same to each other. If a mate’s X45 reads 9000 on my system or his S1R reads 500 then I know he’s got a dud. 1 Maukka calibrated light wouldn’t help, I’d need 4 for low/high flood/throw lumens.
It’s just a case of data collecting to see relative patterns. So if something doesn’t add up I can then theorise why.
(I have many of the same lights too, 3 Olight S1R’s, 2 S2R’s, 2 DQG Tiny’s, 2 Cometas, 3 Blitzwolfs, 3 Nitecore Tips, and 5 Emisar D4’s! and know they measure very close to each other with the same battery and charge level.)
I understand that the tube design is convenient and gives very acceptable results.
An integrating box (which includes the integrating milk carton and the integrating bathroom (shine in one corner, measure in the opposite corner, make sure the light source, yourself and your tooth brush are a consistent colour and position)) in theory (and probably also in practice) gives better results (better integration).
But if you are not happy with how well the tube design integrates, why not go the one extra step and make it a sphere instead of a box, with entrance and measuring hole at 90 degrees and a proper baffle in between? Just because for the past 100 years it is the way to get the best integration.
It’s the only way, as different lights absorb light differently that reflects back from the diffuser. It might only be 5% off one light and 10% off another but it’d bother me. The TA system has another problem that wider heads will absorb more reflection than smaller heads.
Vinh used to say his Sphere maxed out at 20-25k? I can’t remember if he ever said why and surely the baffle on a sphere is gonna f* over the unfeasibly floody X80, X80-GT, DX80 and X45?
The effect of the light in the input port should be corrected by using an auxiliary light. It can add several percent to the error depending on the input port size compared to the total integrating sphere area. Djozz has info on this in his sphere threads.
As long as the light sensor doesn’t see the light itself or the first reflection of the beam directly it’s fine. Assuming the integrating properties are ok. For all less than perfect DIY spheres, you can help the integration a lot by diffusing the light right at the input port so that the flashlight touches the diffuser. I’m using one that came with an LED studio light.
Yeah I’m sitting the light on a very thick diffuser so the light is stupidly linear entering the box, it’s just the light reflecting back into the flashlight head from the diffuser that I think will throw up the occasional abnormality. The entire head area of the Cometa and M43 are very dark. The Emisar D4 isn’t that reflective with the red board behind the optic.
Maukka you’ve measured the X80, did you have to change your methods to cope with the near 180 degrees spill?
