Here is what I was trying to explain to SKV89 about that other picture. The camera can make the hot spot look bigger than it really is.
In your picture above, the hot spot looks more accurate, but I’m guessing you think it’s still too big in your opinion?
The bottom line is that the xhp70/70.2 emitters are just really big. They are not considered good for throwy lights.
In order to get light to travel out to a long distance you need a fairly narrow angle on the beam to keep it concentrated in a small area.
“Throwy” lights pretty much all have a certain ratio of emitter die size to reflector size that allows them to have a tightly focused beam.
The MT07S has a bad ratio for a thrower. A head size of 68mm and an emitter size of 16mm2 x 50% to account for the dome and you have about 24mm2.
Compare that with a xhp35-HI with 5.5mm2 die size. This is 5 times smaller and gives a better ratio with that reflector size putting it into the range of a “thrower”.
Stock the MT07S is rated at about 500 meters with 5k lumen. Doubling the lumen is only going to do so much. It maybe pushes the range out to 700-750 meters or so.
As you change the ratio by going bigger in reflector size the hot spot shrinks and the throw increases. The same xhp70.2 in an L6 probably does 900-1000 meters. In a GT it gets up to 1200-1250 meters (iirc).
Now in the GT, for example, let’s say you slice the dome off. That reduces the “effective” size of the emitter from 24mm2 to 16mm2. This changes the ratio of emitter size to reflector size and moves it more towards a thrower type ratio. Now it will throw 1500-1600 meters.
Then let’s say we change the ratio again by swapping to the xhp35-HI (from 16mm2 to 5.5mm2) in the same GT sized reflector. Even though we loose a lot of lumens, the throw still increases to over 2,000 meters.
This explains why the MT09R in xhp35-HI out throws the xhp70.2 version even though it’s got 1/3 the lumens. The reflectors are the same size, but the emitters are 1/5 the size of the 70.2 (with dome on). So it’s emitter to reflector ratio is more towards the thrower side.
Newlumen, if you want more throw from your MT07S, slicing the dome will definitely do it.
I personally haven’t sliced a 70.2, but TA has. He says you lose a little lumens, but not much. He also says it changed the tint or corona or something. I can’t remember, but I’m sure he could explain it for you.
