The driver ring is not glued, it’s just a left-hand thread …
I feel silly for not trying that now, first time I have seen that to be honest. They went to a lot of trouble to make it happen with reverse threads inside of the normal threads for the body.
Sadly it doesn’t allow you to access the driver as the wires are too short to pull the driver out.
Thank you Texas_Ace for the review, and also for the information about the “lego” you and other member have been giving!
I have one SP32 on the way and I really had that questions about using it with SP31’s tail switch. That’s a “No”, but I’m glad it works with some pieces of the Convoy! ![]()
Please, clarify me:
- about parasitic drain, unscrewing the tailcap would make any difference, or is it too long that one would have to unscrew a lot to stop the drain?
2) you mentioned the “lego” with S2 pieces, not S2, right? So, no chance of operating it with a S2 switch? Or it may depend on the “versions” of the S2+?
Once again, thank you!! :+1:
Best regards!
1: It only takes about 1/4 turn to lock-out the light with either the tailcap or body. So that is an option.
2: It is going to depend on the version of convoy you have, all of my various convoy tube lights lego IIRC but they are all also of the same generation.
Thanks for your answers ![]()
I guess I’ll have to try both things when it arrives ![]()
A last question I just remembered! Do you think the output would benefit from a cell like the INR Samsung 30Q or another for high drain, or it wouldn’t make a real difference if using a Panasonic NCR18650B? (I mention these because they’re the ones I have …)
Thank you and best regards! :+1:
It uses a regulated buck driver, the nice thing about this is that it will maintain the same output regardless of the cell as long as the voltage is above ~3.6v.
Now a high drain cell might end up maintaining that voltage longer due to less voltage sag but overall I doubt you will notice much of a difference either way. It won’t get any brighter with a high drain cell for sure.
Thank you for your answer and explanation once again!
It’s clear for me now!! ![]()
Thanks :+1:
