Ok, as ya’ll know I don’t usually do reviews but I was asked if I wanted to do a review of this light : Amazon.com
I thought I was being offered the dual switch SP31 version which looked very interesting as I am a big fan of dual switch lights. Turned out to be the SP32 side-switch only version that I received. It was free though (well .27 cents but who’s counting lol) so I am not upset since I had some free time this weekend anyways.
You can see SoCalTiger’s review of the SP31 here: [REVIEW] Sofirn SP31 (XP-L2 V6 3D, 1x18650) (Pictures, Beamshots, etc.) The beamshots are the same as SoCalTiger’s and I don’t have any good location to take them myself, so I would recommend looking at his.
Now for the review of this light.
Overall I have to say it is a nice light for what it is.
It arrived in a standard cardboard box with the 2800ma protected button top cell based on a BAK cell (these are reasonably good quality cells out of china), basic usb charger and cable. No lanyard though which was kind of strange seeing as it has a lanyard hole.
First impressions after I took it “apart” and once tossing in a battery are it is quite nice. The UI’s only fault is that it is not Narsil, you really get spoiled once you have narsil. I like that it starts off in moon and goes up with no blinky or strobe modes.
It has mode memory so it will come on with a short click to whatever the last used mode was. If you long press to turn it on it always starts in moon mode which is a nice feature. Turning it off is the best they can with with a long press but without using narsil there is no real way around this.
The mode group is like this:
L > M > H > Turbo
With mode memory
Long click from off enters moon mode
Double click enters strobe mode
Mode spacing is pretty good, I am a big fan of 4 mode groups, mode then that is annoying IMHO.
It also have a nice ramp feature between mode changes much like bistro that gives it a nice feel. Although the ramp is just a tad slower then I would prefer personally but thats just personal preference.
I do wish I has the dual switch version, from tigers review it has exactly the UI I was hoping for with the power being controlled by the tailswitch and the modes by the e-switch.
The threads are nicely square cut and smooth. The springs are also nice and firm with enough give to fit either flat top or protected button top cells.
I wish the pocket clip was a deep carry clip but you can use an A6 / S41 clip on this light, although it doesn’t fit perfectly.
Now for the heart of the light, the LED. It uses an XP-L2 V6 LED which is quite nice. It is advertised as a 5000k tint (my guess is an Easywhite 3 bin) but due to how the XP-L2 looks the hotspot is a bit cooler at I would say ~5500k with a bit warmer corona. It doesn’t have the tint shift “ring” around the outside of the beam though, so that is real nice.
It also appears to be on a DTP copper star, although it was kind of hard to understand the translation.
The LED is classic low ~70cri, nothing special about colors from it other then things are not bright blue.
The heat is very manageable in this light as well, even on turbo it gets warm but not hot. This would be due to the moderate drive currents and efficient driver but it still manages over 1000 lumens while doing that is impressive.
The reflector is much like the A6 but appears to be a bit deeper and it is SMO instead of OP. I think an OP reflector would have been the better option in this case but the SMO works surprisingly well.
Side by side with the A6 3D the beam pattern is virtually the same (the A6 is a bit smoother due to the OP naturally) but the S1 3D tint actually looks green when compared with the SP31. I have to say, I actually prefer the SP31 beam over the A6.
The only real complaint I have with this light other then not being the dual switch version is the e-switch itself. It will sometimes not detect the click even though I can feel it click. So I have to press a bit harder to get it to detect the click. Not a major deal but a little annoying. EDIT: After talking to some others with this light and Sofirn I am pretty sure that my switch issues are a fluke with my sample light. It does not appear to be a common problem.
Now for some tech specs and measurements.
My interests tend to focus more on the technical aspects of a light then cosmetic, so naturally that is how my reviews will go as well. These numbers are off my sphere used for the LED tests in my sig along with my bench power supply for the driver tests.
This light is rated at 960 lumens on turbo. In my testing I got a bit over 1100 lumens at turbo on and it stabilized just under 1100 lumens by 30 seconds. Pretty nice to see a flashlight that is underrated instead of overrated!
Approx Lumens by mode (rounded slightly to make it easier to read)
Moon - 1
Low - 14
Medium - 140
High - 500
Turbo - 1100
The mode spacing is good, I like the moon to med spacing for sure, I setup my own lights with very similar spacing. High and turbo are a bit close together for my tastes. I personally go from ~150-200 lumens in med mode to ~1000 lumens in high on my lights and find it to work very well. Since they put moon mode in a septate section (aka, long click from off) I can see why they did it this way though.
The glass lens also appears to have some kind of AR coating. Not the best coating I have seen for sure but good to at least see the effort. The glass is very clear and I expect minimal losses from it.
This light is powered by a buck driver that can handle up to 6V input voltage (2x CR123) and does a really good job at keeping a constant regulated output. From 3.8v up to 6V it maintained almost exactly 10W of power output and held that until it stepped down from turbo mode after ~3 mins. This translates to around 2.8-3A on a DMM although for buck drivers Amps is not a very usable measurement.
After the first ~30 seconds of “minor stabilizing losses” the output remained almost unchanged until I stopped checking ~5 minutes later. This is a good sign the the heat path is good enough to not cause a drop in output while the driver maintains the current.
Around 3.7-3.8V the output increased slightly as it started to fall out of regulation. It then fell out of regulation entirely at ~3.6v. This is impressive, it then started to drop output with voltage but was still over 900 lumens at 3.5V.
Low voltage appears to start kicking in about as advertised at ~3.1V.
The parasitic drain is about 0.2ma, higher then I would like to see but not unacceptable. It should still get you over 1.5 years before draining the included battery and the battery it comes with is protected. This is another reason to get the dual switch version, it would have zero drain while off.
Overall this is a very good driver indeed. It just needs narsil and it would be great.
Now for the bad news, this light is good as it comes stock but sadly for most that is all it will ever be. Both the driver and reflector are glued down tight. You can see traces of the glue on the threads if you look close. I tried opening them up but it started to bend my pliers on the retaining ring. I really like the light and didn’t feel like damaging it to get it apart right now. This is disappointing for modders but a non-issue for everyone else.
Conclusion time
Overall I really like this light, after seeing this I want to try out an XP-L2 EDC light for myself. If this was the dual switch SP31 model I would even consider carrying this light as an EDC. I am not a fan of side switch only lights though, I feel it is too hard to find the switch in the dark when you need it. I always know where the tailswitch is on the other hand.
So if you want to get one of these, I highly recommend springing for the dual switch SP31 model. This would make a great gift for just about anyone. This set will handle 90% of lighting tasks people may need inside ~100ft.
I would put it above the A6 / S1 for your “normal person” since it doesn’t get burning hot in seconds and is much more practical due to this. Although it does give up a bit of output for this practicality but not enough to notice in most situations. I had to try them side by side to notice in the real world.
Also it is good to support a company that not only correctly rates the output of their lights but even under rates that. I am so tired of the bloated and overrated lights out there.
