Vote for your favorite build of The 12th Annual Old-Lumens Challenge!
This poll will close after 14 days. (Start: February 17th | End: March 3rd, 2025)
The results will be shown after the poll is closed.
- Ruckusmattster
- GorgTech
- chipmunk
- MtnDon
- Worrub918
- Hunter-Jackson
- TheEinherjar
- YuvalS
- RobotSquid
- koef3
- Pinkpanda3310
- Dandyhorse
- Skylight
- turbiny
- NeutralFan
- Saltyboi6704
- QReciprocity42
- Serlite
- clockwork
Please familiarize yourself with the builds before casting your vote:
Top row, left to right:
Ruckusmattster, GorgTech, chipmunk, MtnDon, Worrub918, Hunter-Jackson, TheEinherjar
Middle row, left to right:
YuvalS, RobotSquid, koef3, Pinkpanda3310, Dandyhorse, Skylight
Bottom row, left to right:
turbiny, NeutralFan, Saltyboi6704, QReciprocity42, Serlite, clockwork
A brief description of the builds:
Ruckusmattster made a 9Mcd 20k lumen Short Arc searchlight out of scavenged parts.
GorgTech designed and 3d printed a golden desk lamp with articulating neck.
chipmunk designed and 3d printed a four legged task light, featuring an adjustable spot size.
MtnDon fabricated a rectangular light from metal tubing and wood, with a triple optic and wood accents.
Worrub918 transformed an old Mag-lite, with dual channel output and Anduril 2 firmware.
Hunter-Jackson outfitted a Convoy L7 with a large triple optic and three SFT40 LEDs.
TheEinherjar made a clicky flashlight out of a disposable vape tube and some parts, featuring built in USB charging.
YuvalS successfully made a copper flashlight by means of a novel wire wrap construction technique.
RobotSquid designed and fabricated a dual channel headlamp, with custom driver and firmware.
koef3 turned an old LEDLENSER V2 into a triple triple, with nine LEDs, a new switch, and custom battery carrier.
Pinkpanda3310 gave a Convoy S2+ a magnetically controlled illuminated tailcap.
Dandyhorse fit a Ledil Anna 7-lens spot optic and 7x 519A LEDs into an orange Convoy C8+.
Skylight converted a Starfish X40 into a triple XHP70.3 HI light, and baked the anodize to achieve a dark green finish.
turbiny took a light from childhood and gave it new life as a UV light, with 5mm UV LEDs.
NeutralFan made a lantern out of a green metal canister and other parts on hand.
Saltyboi6704 utilized 3d printing to build an actively cooled RGB accent light, featuring custom controls and USB charging.
QReciprocity42 made a Convoy S2+ mule light, with 12x Seoul SunLike violet-pumped emitters, and with an illuminated tailcap.
Serlite turned a wooden picture frame box into a desk lamp, with ample diffusion.
clockwork made super low power bullet style LED marker lights, an alternative to tritium vials.
