I got one of the E09’s for my wife too after she saw mine. Both being used on Keyrings. It is the red one but looks more pink/purple. She loves it.
I too would be interested in some kind of keyring pouch/holder.
Tank has always had some of the worst "make you want to vomit PWM"
Tanks foul PWM has become ledgendary ...
I'm a great lover of tank lights but this is a serious flaw that takes a great light and makes it an OK light . If they refuse to fix the problem then maybe they need to stick to one mode lights. The $5 thrunite ti still makes more sense...(even though I dislike thrunite for their spamming /shilling activities on blf )
2 Victorinox mini pouches should fit:
Vinox key fob pouchtoo cheap material dont even go there
Vinox hang pouchtoo short, for 58mm SAK's
Am I the only one here that totally disagree’s that PWM is a “serious flaw”?
I do not even notice it on my PWN lights. If it is even worse on my E09 just because it is a Tank brand, I can’t tell.
I find shining the light on water falling from a shower head strangely entertaining, but other than that, the light is the same as all my others.
Does PWN possibly effect the eye’s of some more than others? Boaz, it sounds like PWN gives you a serious headache!
I do notice that my E09’s have strong PWM when I point it at the ceiling fan, but other than that I’m not particularly sensitive to it. I guess some folks are more sensitive to that than others.
For example, I’m really sensitive to (relative) pitch. The tiniest variation of pitch (sharp/flat) and I’m cringing. That’s why I don’t like hate karaoke J) . You’d have to put a gun to my head to get me into a karaoke lounge. Ha Ha !
Sorry Boaz. I did some quick research and found out that PWM does effect people differently. PWM does not seem to bother me at all.
Good thread about PWM here….
After baking my trusty P7 last night, I was trying to improve the pictures from my iPhone and I happened to shine one of my flashlights on the P7 in low in an attempt to keep the flash from going off. This is what came up: [image] I had heard of using hand in front of the lamp, shining it on a fan or showerhead, but never heard of this. I tried it on several other lights and got the same thing, but only on some and usually only in low mode. Image appears on the iPhone preview as well as in the…
I never laughed harder than at the video you posted in that same thread (post # 38)
good stuff
I can see PWM fairly easily, even at frequencies of 4.5 kHz (fastest I’ve been able to try), but it doesn’t really bother me. I actually rather like the really low PWM frequencies sometimes because it works as a makeshift strobe light.
If you want to check a light for PWM, the easiest way I’ve found is to rapidly move a white business card through the beam with a dark background behind. Just wave it back and forth quickly, and you should see either a bunch of discrete frames or a continuous blur.
Oddly enough, I just discovered something while trying this. Much to my surprise, there appears to be PWM on my Zebralight SC52 on L1 (2.7lm) mode. It appears to be partial, though, like… not 0% with brief flashes of 100, but more like alternating between 1 and 5%. Has anyone else noticed this?
Thanks BBob!
I couldn’t resis and had to get one as well.
Thanks for the write up
NTB
Tank has always had some of the worst “make you want to vomit PWM”
Thanks for the warning, Boaz. I don’t have any lights with PWM but I am very sensitive to flickering lights. So maybe I should give this one a miss.
I have this from a BLF giveaway and to my surprise it performs very well with eneloop aaa.
This makes it a perfect gift aaa light.
It looks neat, but I wish it didn’t have PWM. At least the ES12 looks like it has constant current.
i have ES12. it has de same driver as E09 :)
It’s not constant current, then? ![]()
On the CPF thread the OP posted the specs, which has the following line:
Output Levels: 3 mode (Constant current circuit chip which maintains constant brightness)
On the CPF thread the OP posted the specs, which has the following line: Output Levels: 3 mode (Constant current circuit chip which maintains constant brightness)
this is a joke of a "review", nonetheless it contains good pointers, you only need to follow the embedded links in it:
Tank007 ES12 kresil's Overall Rating: ★★★★☆ [image] Summary: Battery: 1x AAA/10440 Switch: twisty Modes: 3 w/ mode memory (—Med—Lo—Hi—) LED Type: XP-E R3 Lens: glass Tailstands: yes Price Paid: 25$ From: WB Date Ordered: April 2013 Pros: measured 90+ Fenix lumens output, bright spill, tight bright hotspot good regulation with constant current driver very good looks, superior fit and finish, feels very expensive Cons: low frequency PWM (as common with all Tank00…
Yeah I am sensitive to low PWM . The new car taillights just freak me out with long trailing red comet tails . I can deal with higher PWM and still know it's there and not get all crazy about it . I have a few lights I like really well that have cool Ui's that have lower pwm and just have to deal with it ...So yeah If I have any ability to make that go away I'll take the opportunity to do so...IMO lifes too short to deal with flashies or funky PWM if you don't have to ..
That said ... The tank lights have always been some of my favorites because of their excellent design and quality bodies ..
run them on high :P
