The Coleman Gas Lantern that runs on LiIon..
I built an “LED module” that can convert any Coleman-style Gas Lantern to LED and LiIon cells without modifying or altering the lantern itself. (meaning it takes roughly 60 seconds to convert the lantern back to Gas operational.)
Its sort of “best of both worlds” in lantern technology i guess.
This LED module, simulates the original Gas Mantle light and tint very closely, anf has 2 modes, (High & Low) can run on either a single, 2, 3 or four rechargeable 18650 Cells, and with four 18650’s with roughly 1800mah each, it gets 12 + hours on High before the driver steps it down to low to protect the cells from over discharging. its output on high after 30 minutes is roughly 450 - 500 lumens, and close to the output of a Coleman Model # 222 Gas lantern or most single-mantle Propane lanterns.
The module uses a Cree XM-L2 3000K Warm White emitter, and a two-7135 chip 105C driver, with remote switch.
Below is the module working in a 1977 Coleman Model #335:
Below is what the module looks like out of a lantern:
Below is a collage of pics of the parts of the module how i built it.
First i used some bare parts, copper plate & a heavy brass fitting for Heatsink, a Nanjq 105C Flashlight Driver, a CREE XM-L2 Warm White 3000K Emitter, two double-18650 LithiumIon Cell holders, some wire, a switch, some shrink tube, some velcro-webbing, and a plastic shade/diffuser with netting over it to simulate a mantle. With some soldering, drilling, and gluing, the simple module can work in almost any single mantle lantern to simulate it as working on gas, only without the heat and hiss noise.
The module’s battery packs just “hang” over the gas frame hidden under the vent, while the “fake” mantle with LED holds on to the burner with a set screw, and the switch simply hangs out of one of the holes in the globe base.
that mod is amazing… lovely setup with that LED.
I especially like “reversible” mods as I just can’t seem to commit. :slight_smile:
Something old, something new. All in the same package!
With this Module i can use a gas or propane lantern on gas while camping, then switch to LED if i run out of fuel, or vice-versa if the batteries get low i can switch to Gas operation by removing the module & adding a real mantle & fuel.
Wow! What a fantastic creation. I always loved the Coleman lanterns I grew up with in the 60's. Nostalgic for sure. Great work and you've given me an idea for a project come some rainy day.
Very creative. I did wonder where you put the batteries. I'll take two please.
I can tell you I thought I would never
See a lantern mod so very clever
An idea abstract
Turned into a fact
What a truly amazing endeavor
The four 18650’s all run in parallel, So its safe with a great run time on high and runs for a week or more continuous on low. Also it can run on only one, two, or three 18650s if needed.
it uses a Nanjq Q-Lite Rev. driver meaning it can have 3-modes with moonlight if the star-bridging is changed.
You have simply got to secure a patent for this! No one else should be able to make money from your invention.
Good GREAT job!
Pat pend might be better, cheaper and does not release the dsign.
BUT the important thing is DO NOT have it made in china!!! :smiley:
I like, you can also use with 4NiMH
If you decide to sell kits i’m in for at least one
The nice thing is the lantern acts as the heatsink
indeed four NiMH cells in series work just fine. I may make a few more of these as i have enough extra parts and components here in my bins.
I noticed Fasttech sells AA battery holders, i think i saw a 16 battery in series holder once (this only needs four in series of course), but i figured this would be good for my folks since they are now thinking of buying a few candles or $50 LED lantern that runs on many D batteries (took me a while to talk them out of it) hence I am actually looking for a good 4AA lantern.
Wow! would really like to see this indoor friendly solution on a Primus/Optimus style lantern.
This module should get reasonable run times using four Ladda or Eneloops and double that if using eight AA NiMH cells. ( in a 4S2P config.) I used only two 7135 chips on the Q-Lite in this module to keep the LED in that “efficient zone” (on high at about 0.74 amps i measured and it barely warmed up on the hefty copper block module.) and still puts out lots of light with a full weekend worth of run time on a single charged set of old 18650 laptop-pulls.
As for other 4-AA lanterns, i lost count of the ones i built, modded, and have scattered all over the house and RV.
This module would work on the larger Primus or Optimus lanterns as long there was enough room under the top vent to hide the battery packs. ( though i dont have any of those makes or models, the closest one i have is a Petromax style.
So far i don’t have a host yet, but i’ve been enjoying the starry light and it has good modes, so i am reasonably confident i can program a 105C (won a programmer in a giveaway, have not tried it yet), i figured 4AA in series, on a swappable plug like those cheap bike lights, at 200mA it would last 10 hours (about 100 lumens), then swap for the next battery pack (4AA).
Your host seems excellent because most cheap hosts are plastic and provide no heatsinking at all, if i make a light like this i can hopefully come across an old lantern for a few bucks somewhere
Where is the diffuser your using from?
These lanterns are meant to withstand a lot of heat and with all the frame made from steel, (many older models like the 236 - 237 used solid cast brass burners and gas frames, which make great heatsinks.
The diffuser is one i salvaged from an old garden LED light, with a piece of white hair-net over it to simulate a lantern mantle.
I know, thats why i am sure they would handle LED heat without difficulty unlike dollar store lanterns.
If there is a cheap diffuser available that would be great for this mod.
So far of all the diffusers i tried (even factory ones) the one that came with my Sunwayman F40A is the best i tried with the least loss of LED output.
