This is on manual and the first number at the bottom was 4 and the focal was 4 and the ISO was 200. I hope this helps you. Both were taken on the same magnification. I put some other Xtar 18700 2600MAH in the 7G5 before this shot. They measured 4.20 and 4.18 volts. I just want to be fair. I left the same 4.10 volt Hi-Max 2600MAH batteries in the M3X. Now I took 4 shots from each light and picked the better focused one from each light. And the girls left so I had to take each separately.
Pls dont misunderstand bro, of coz not saying you are lying. If you look at my shot the 7G5 definitely is not blue in fact its v slightly greenish, the xr-e is actually WD (such is the high chance of being able to present different results from the naked eyes).
Seems like the last photo set of yours shows, in your case, the m3x really has that advantage in throw. It is always good to have more pix and info.
Damit, so now i have got to have the m3x into the collection. The good thing is, i dont have any Olights. Lol! And i still want the V60C... All v good prices, as being a good value for money person i'd never buy them at $155 and $130. (I already have lot of budget lights)
PS. No worries, your cells at even 3.9V open circuit is just fine for operation, much less 4.0V. The lights are well regulated with the 2 cells. (1 cell for a well-gunned XM-L is a totally different story esp if your cell is not so good)
No problem 2100. I'm not a big camera person so I don't know much about the settings. And my Fuji S8000FD 8.1 megapixel camera I'm sure is nowhere near the camera as you have or others here. But it seems to serve my pupose well. I knew before I bought the Crelant 7G5 that is was going to have to be one bad thower to beat the M3X. Marshall from goinggear.com has shown the M3X on his videos and redforest here has told me that the M3X is one of the best XM-L throwers period. I can now say they are right.
ILIKEFLASHLIGHTS, I was just about ready to pull the plug on the Crelant, but after this report of yours I'm not so sure. I already have a good (budget) thrower in the STL V6, but I want something a little better. Maybe the M3X will do it for me
PWM is when in medium or low modes, you wave your hands/fingers very quickly in front of the light, and you don't see that "strobe effect" - ie very smooth constant stream of light. No strobe effect = either no PWM or the PWM frequency is too high to be visible. There are other ways to measure that but this the quick and dirty way and is good enough for most.
There can never be too many lights, but alas the wallet is thin and mind is weak!
I have done a new search on CPF (I have searched for the light before), seems like there are some posts and reports on the M3X but because it is an early model, not many have done 1-1 comparisons like this.
That's cool! Thanks! That's because the M31 Triton has PWM. Actually the Skilhunt lights (new brand) also has PWM. Most budget lights (95%) have pretty low PWM.
[/quote]
Ditto.
2100, d'ya think the M3X is worth buying over the Crelant? I mean the price (of the Olight) here in Singapore is almost 2 and a half times that of the 7G5 .
You can get the batteries, the Trustfire Flames protected, for 8.39 - 2 bucks = usd6.39...if you use ddchristmas coupon code for battery + flashlight purchase. Just nice and very good price (the cells are $10 elsewhere). Do use Paypal.
...Like you a have use for the other dozens of lights... LOL.
I don't have any use, too. It's just a 'collecting' bug.
Anyway, back on the topic. This is not right if a light that's driven harder and has deeper reflector scores less. Something is blocking 7G5 potential ...I'll try to swap the LED and see if it changes something. Or maybe ILF's M3X is some serious overachiever.
Coolperl, that's why it's also good to collect other data like ceiling bounce (vs other known lights), output sag due to heat (emitter might not be seated properly /HS compound not enough) etc. Like DrJone's TK35 clone, his copy only had like 10% HS compound covering the star while mine was crazy but i improved it further (stock form it sagged only 3% in 9 minutes).
