In a practical sense, I was happy with the LatticeBright LED flashlight. It was bright enough and the battery life was pretty good. About 20 seconds after deciding that, two questions came to mind:
âHow bright is bright enough?â
âWhatâs the big difference between the LatticeBright clones and the Real Cree?â
Suddenly my flashy new imported tactical flashlight wasnât satisfactory anymore. It was supposed to have a Cree LED in it and instead it had a clone! I had no idea what that meant except for the cost did seem unusually low for what was advertised as a top tier item. As my thoughts carried me though the rationalization process an image started to form. The only way that I was going find answers to my questions was to obtain a genuine Cree LED. From The LED Store. I purchased one each of three genuine Cree XM-L2 LEDs that were offered: Warm white, Neutral white, and Cool white. These came pre-soldered to 20mm âLuxDriveâ bases.
After they arrived I was quick to disassemble the flashlight and replace the LatticeBright clone with a genuine Cree LED. Anticipation was high when I got it all back together, popped in a battery and turned it on. I started with Warm White. After turning it on, I noticed immediately how much better the Warm White LED looked in comparison to the mostly blue-ish light from the clone. That in itself was impressive. When it came to brightness though, I wasnât satisfied. It didnât seem that much brighter. Next, I got out my ammeter and measured the current draw from the battery. I had previously measured the current consumption with the clone at 1.25 amps. The Cree LED consumed only slightly more current. According to the spec sheet, the Cree can be driven at 3 amps. This means that the driver circuit in my flashlight was only driving the LED at about 45% of rated capacity. OK, then - I got online and ordered a driver board capable of supplying a full 3 amps of current to my genuine Cree LED.
I must say that after installing the new driver board that at last I had found satisfaction! The genuine Cree LEDâs performance was impressive and satisfying! Finally, I had my extreme tactical flashlight! I tried all of the LEDs and while the Cool White seemed the brightest, the Neutral White was my favorite!
For anyone wanting to do the same I recommend measuring your original star base and driver board before spending any money. Make sure you get the right size. My original driver board was a 20mm and the upgrade driver board was 17mm so I had to adapt it. I made a ring of 16ga solid bare copper and soldered it to the circumference (GND) of the driver PC board.
Driving the Cree XM-L2 at maximum rated current generates some heat. The flashlight body that I used has a threaded copper ring to seat the star base. I used the original clear plastic insulator under the copper ring and so far I havenât had any problems with it.
According to the manufacturerâs spec sheets, at 3 amps my Cree XM-L2 Neutral White LED from the T5 bin has a calculated light output between 950 and 1000 lumens. Itâ very bright and Iâm very happy with it!
