Quick story I thought I'd share, since I'm pretty impressed w/ Cree quality...
I've been playing w/ a tractor supply 3xD zoomie. I added mass to the pill, put in an xm-l u2, tried direct drive w/ the stock alkalines and they'd only feed an amp.
put in some energizer Ds - poof - nothing happened, visually (output or physically...on the emitter itself) but no more light will come from that emitter.
next xm-l u2 - tried KD 3xAA holders w/ 1600mah Panasonic NiMh (3s3p). Got about 2 amps. Did some resistance fixes to the holders, the switch and the tail and got about 2.8A.
Should have stopped.
Took 3 Tenergy 10A Ds, charged to ~1.36V, and just tapped the ammeter at the tail - it would flash over 3A. Held it for a second or so and removed the leads when I saw a bit over 5A.
Went to 2 of the KD holders and 1D. got about 3.5A so I did some white wall hunting and saw a big, bluish, line across the emitter image when focused
So, I inspected it and there seemed to be a crack in the emitter, but it was hard to tell.
There was certainly a crack inside the dome that didn't reach the outside. this started at the emitter but didn't reach the top of the dome and was almost all the way across - and it looked like the crack a stone would make in your windshield.
Well, I figured, the heck w/ it, I'll use it and when new emitters (and proper drivers) arrive, I'll put that xm-l in a flood light.
Well - 20 minutes of direct drive use later (3.5 waning to ~2.5A) it has healed itself - the crack in the dome has almost completely disappeared and the emitter surface looks fine.
weird
