Looks like I got the lux readings wrong, but TurboBB’s readings show 1040 lumens and 57k lux
I don’t know why your lights aren’t throwing more than 200 meters, but to have such bad luck… one cannot help but question the owner’s testing methods.
Google earth underestimates distances by a long way by my findings. i paced out my street from my house to the bottom of the road. it was 150 yards, google earth measured it at 90…
Double check mate, no disrespect but I’d trust the google earth reading above most others methods when there’s that much difference! How did you do your measurement?
Got mine on a gladiator running all 4 cells, it’s a great bit of kit but really needs to be driven harder. It’s outclassed when put in its price bracket.
When I test a light I take it to a football field at least I know it will be exactly 100 yards…. When the lights hit the outside fence 150 yards… When it hits the baseball field 200 yards, when it hits houses and people walking dogs, 300 yards …… When it hits the smallest tree I saw during the day and it looks an inch hi from where I am and its really 40 feet tall 500 yards …… Above 500 yards you need binoculars !!!
Checked out your youtube video of the flashlight collection you have…that’s some pretty good collection you have going.
The last torch (SST) was enormous!!
OK, think the main chart is pretty accurate waiting some new lights to raise the bar now.
So ive added a couple of Modded slots into the lower chart. Suggestions please…… Must be an easy mod, links to drivers/emitters appreciated along with a estimated Lux value.
Edit, Added Ledsmoke and Manny’s suggestions for now, other suggestions still welcome
Opened the led hole in the reflector bottom up to 15 mm with a little round file. 5 minute job and then 15 minutes getting the debris off the reflector without touching it with anything but warm water and compressed air.
Changed SST-50 led to:
LED-tech T6 on copper core star: with original 3 mode driver running off 2 batteries: 80 kCd
The led stars were lapped flat onto the light and clamped down with thermal epoxy and screws.
I tried only these two because the second one is so good that I do not want to run the risk of going lower again. But I think the variance in emitters and mounting makes it worthwhile to buy several and test them. The base plate of the DX one seems to be fairly pure copper. It is very soft and apparently quite good at transferring heat.
A stock X6 is around 1500 OTF lumens with around 80k lux already (6.5 amps).
I think at 9 amps it should be close to the 100k lux figure (I hope). But we won’t know until I receive it!
I figured my old Fenix TA21 was getting a little long in the tooth so after a long bout of indisicion and flip flopping I finally ordered the Xeno G42 v2 neutral. It’s in the mail…can’t wait.
I doubt that a stock Trustfire X6 will produce the same amount of OTF lumens that a SR90 will. That’s about what a SR90 is said to do realistically or 1400 lumens. And a SR90 puts out about 113,000k lux @ 1m.
I don’t doubt it, because if you think about it, for an SST90 it’s not hard to output 1500 lumens. According to this it only takes 5.4 amps to the LED to produce 1500 lumens, and the X6 has a 6.5A driver, so if you take away that .9A (which gives you an efficiency of 83%) then it looks quite plausible that the X6 will output 1500 lumens or more.
EDIT: The SR90 has a head diameter of 100mm while the X6 has one of 80mm so you can understand why the lux is lower on the X6.
